Painting galvanized metal
When I worked in a fab shop years ago, we used a lot of galvanized material. The painters always wiped the galvanized metal down with white vinegar before painting.
CH,
I used to do a lot of home repair work for people. When I would install galvanized gutters and down spouts, I used a galvanized primer that I bought at Sherwin-Williams before i painted the gutters. The primer was a bluish color and it felt almost like a plastic coating when it dried.
Seemed to work pretty well - at least I never got any callbacks for peeling paint. You might check with Sherwin-Williams.
Tom in TN
You neeed a zinc chromate primer. It will etch into the galvanising and provide a surface for your paint to stick.
If the galvanizing is weathered but not rusty You can use a good latex paint over it and it will last for 10 years. If it is rusty then use Rusty Iron Primer by Rustoleum. Wait a week before putting final coat on. I have painted many galvanized metal buildings this way and they all turned out good with no failures. But if there is rust you have to use the primer I suggested.
Ammonia:
solution of 1-2% ammonia applied with a nylon brush can also be used, although this method typically is reserved for cleaning parts with ash residue. After cleaning, thoroughly rinse the surface with hot water and allow complete drying.
