TractorLinks.com
Tool Talk Discussion Forum
Re: New generator. Wiring up an hour meter
Bob M
02-25-2013 18:41:56
You certain your generator has a 120 volt RV (TT-30) receptacle? If yes, you can safely power your Hobbs 120 volt meter with a suitable plug and cord as you propose.
However if the generator receptacle is the somewhat similar-looking NEMA 6-30R (240 volt with no neutral) it won't work.
R Wyler
02-25-2013 18:49:14
 Re: New generator. Wiring up an hour meter in reply to Bob M, 02-25-2013 18:41:56
I will make certain but if I understand right it is a 120 Volt outlet for a big power cord. I think the model above mine has a 240 Volt outlet. I will make sure though before hooking it up. Thanks for the response.
Bob M
02-25-2013 19:07:08
 Re: New generator. Wiring up an hour meter in reply to R Wyler, 02-25-2013 18:49:14
If it's a 120 volt outlet (which I suspect it is) you should be fine!
Photos at this link should help you verify exactly what you have.
R Wyler
02-25-2013 19:33:33
 Re: New generator. Wiring up an hour meter in reply to Bob M, 02-25-2013 19:07:08
Thanks for the link that is great info. I will make sure of what that outlet is. If it is 120 Volt I might put a small 110 standard plug in the cord so that I could run the meter off one of the small receptacles if I ever wanted to use the big plug in. Thanks again for the help!!
