TractorLinks.com
Tool Talk Discussion Forum
Re: Ground for a welder
John T
02-25-2013 13:55:04
Good post, I will try to explain it for you in simple terms so as to NOT loose you, here goes.
If its an AC Buzz Box Welder its an isolation transformer and if theres no leaks or shorts the ONLY voltage difference is between the leads, stinger and the groung clamp, none with respect to mother earth or the concrete floor or structural building steel from either lead. Thats notwithstanding inductive and capacitance which can create some other potentials but those are low energy. Soooooooooo if one part of a farmers body is in contact with say the stinger or metal its in contact with and another part of the body is in contact with the ground clamp or metal or water or earth etc its in contact with THAT VOLTAGE CAN CAUSE A CURRENT FLOW and it only takes maybe 30 TO 50 milliamps across the ticker to cause it to de fibrillate and YOU DIE. If you put one hand on the stinger and another on the ground clamp theres a voltage difference and current can flow.......Same if youre lying on the wet ground or up againstg a metal farm implement etc that either the stinger or ground are contacting you can get shocked
Got it???????
John T
JOB
02-25-2013 16:27:38
 Re: Ground for a welder in reply to John T, 02-25-2013 13:55:04
Not entirely, I do not understand the weird things electricity can do. I had heard that it only takes a couple of milliamps across the ticker to put you into that eternal sleep. The post above this one from David G, his dog put his wet nose to a trailer that was being welded on, and it sounds like he got bit by something.
Aboard ship when in an engine room and welding I would get a tingle when putting an electrode in the stinger if I was not wearing a dry glove and standing on a wet deck.
John T
02-25-2013 17:38:31
 Re: Ground for a welder in reply to JOB, 02-25-2013 16:27:38
A GFCI is designed to trip around 5 milliamps and this is for an approximate safety factor of ten times. Typical figures Ive seen for defibrilation are 30 to 50 milliamps.
Again the voltage output of a buzz box AC transformer welder is between/across its leads (stinger and ground NOT either lead to other AC wiring) but one or both of those leads are against metal or on concrete or wet mother earth and if your body gets between one or the other (or water or metal etc) you get shocked..
Electricity doesnt necessarily do weird things (from an engineers perspective), current simply tries to flow anytime theres a voltage difference and ohms law defines how much in whatever paths are available subject to the paths resistance.
Hang in there, youre comin around
John T
