| Author |
[Modern View]
| R Wyler
02-25-2013 11:00:27
70.137.2.194
I use a generator at the farm because I don"t have electric out there. Anyhow I just bought a new 3500 watt Briggs generator. It has 2 regular outlets and also a 120v RV plug outlet. I don"t load it heavy just a single power tool and sometimes the well pump. I have a new 120V Hobbs meter on the way. I plant to get a plug for the RV outlet and run a cord to the meter. Is there a better way? I don"t want to take the outlet box apart on a new generator and cobble it up. I do want an hour meter though. Any thing wrong with doing it like this? |
| Billy Shafer
02-27-2013 06:48:42
173.184.46.120
Re: New generator. Wiring up an hour meter in reply to R Wyler, 02-25-2013 11:00:27
| You could just get a Tiny Tach. Hooks around the plug wire. Hour meter and Tach all in one. |
| George Marsh
02-27-2013 11:48:42
50.104.195.160
Re: New generator. Wiring up an hour meter in reply to Billy Shafer, 02-27-2013 06:48:42
| Billy, I purchased one like you described on ebay, China. It only lasted about 10 hrs. The battery inside went dead. Battery was soldered in too. Got a full refund and kept the tack/hr meter. George |
| Bob M
02-25-2013 18:41:56
74.67.191.60
| | You certain your generator has a 120 volt RV (TT-30) receptacle? If yes, you can safely power your Hobbs 120 volt meter with a suitable plug and cord as you propose. However if the generator receptacle is the somewhat similar-looking NEMA 6-30R (240 volt with no neutral) it won't work. |
| R Wyler
02-25-2013 18:49:14
70.137.2.194
Re: New generator. Wiring up an hour meter in reply to Bob M, 02-25-2013 18:41:56
| I will make certain but if I understand right it is a 120 Volt outlet for a big power cord. I think the model above mine has a 240 Volt outlet. I will make sure though before hooking it up. Thanks for the response. |
| Bob M
02-25-2013 19:07:08
74.67.191.60
Re: New generator. Wiring up an hour meter in reply to R Wyler, 02-25-2013 18:49:14
| | If it's a 120 volt outlet (which I suspect it is) you should be fine! Photos at this link should help you verify exactly what you have. |
| R Wyler
02-25-2013 19:33:33
70.137.2.194
Re: New generator. Wiring up an hour meter in reply to Bob M, 02-25-2013 19:07:08
| Thanks for the link that is great info. I will make sure of what that outlet is. If it is 120 Volt I might put a small 110 standard plug in the cord so that I could run the meter off one of the small receptacles if I ever wanted to use the big plug in. Thanks again for the help!! |
| magpiene
02-25-2013 13:13:39
204.54.154.78
| I am not sure what to look for. But there is an hour meter that runs on the engine ignition, check with the lawn mower people. |
| R Wyler
02-25-2013 14:01:56
70.137.2.194
Re: New generator. Wiring up an hour meter in reply to magpiene, 02-25-2013 13:13:39
| Thanks. I found some about them online it looks like they have a long lived battery in them and I think that they use a wire that wraps around the plug wire. Maybe that I should have used that instead. I plan to put meters on the tractors also. They are a good thing to have. |
| bill mart
02-27-2013 06:41:27
69.204.65.189
Re: New generator. Wiring up an hour meter in reply to R Wyler, 02-25-2013 14:01:56
| There are hour meters out there that dont use a battery.They get their power from the running engine.Respond to this post if you would like the brand name.(got to out to the garage to find it) Bill |
