Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Silver soldering stainless steel
welding man
02-25-2013 04:31:51
There are several grades of silver solder also. Depending on the silver content.Make sure you get one that is forulated for stainless and the right flux is imperative.
missouri massey man
02-25-2013 05:08:36
 Re: Silver soldering stainless steel in reply to welding man, 02-25-2013 04:31:51
Whoops, I forgot about the different solders:
Staybrite 8 is an 8% silverbearing soft solder whose melting point is really low, low enough for Mapp or Propane or Acetylene only (Prestolite), but not a good choice for this application. It comes in a roll.
Stay-silv makes a 6% or 15% silver solder, but it will be difficult to make a steel bond, but if you try it, make sure you use the Harris white paste flux only. These come in sticks, one pound to the pack.
What I use for this application is 45% or 56% silver that is sold by the troy ounce and should be available at the local air conditioning supply house. Locally, 45% currently costs $31.60 per troy ounce. This comes in a coil, usually in a hard plastic case. The Harris white paste flux would be the one to use with this product. Good Luck.
