TractorLinks.com
Tool Talk Discussion Forum
Re: Sharpest knife you have?
old
02-24-2013 15:05:04
I try to keep ALL my knifes shape as in so sharp you can shave the hair off your arm. That is how I check them to see if they are sharp enough to put them away. I also try to keep my axes and hatchets as sharp as I can and have had more then one person get surprised when I can skin a deer with an axe
GUIDO
02-24-2013 19:49:03
 Re: Sharpest knife you have? in reply to old, 02-24-2013 15:05:04
Hello old,
You are like me, when it comes time to sharpen things.I check mine on my arm as well.
Ceramic rods will do the final touch.
I don't remember, when I sharpened my kitchen knives. Before I put them away, the get a few shots on the steel, even the serrated ones.
Much better to get cut with a sharp knive, dull ones will leave a wide gash.
Guido.
old
02-25-2013 08:54:57
 Re: Sharpest knife you have? in reply to GUIDO, 02-24-2013 19:49:03
Ya I learned many many years ago it is the dull knife or tool that you get cut with and never a Sharpe one because a dull one you have to force to cut something so you use to much pressure and that pressure in turn makes you slip and you then cut your self
GUIDO
02-25-2013 12:28:04
 Re: Sharpest knife you have? in reply to old, 02-25-2013 08:54:57
Hello old,
You are right, i rather get cut with a sharp knife then a dull one.
Here is what i use for my knives.
The wet stone is about 12" long, and sits inside a piece of cherry that I routed out. This makes the stone stationary.Legs and non slipp material finished the tool. Also I have a set of ceramic rods which I use after the stone.
It works for me.........................
Guido.
old
02-25-2013 13:33:32
 Re: Sharpest knife you have? in reply to GUIDO, 02-25-2013 12:28:04
I have probably close to 10 wet stones. Most I picked up used for here and there and some are so old they are sway backed as in have been used so much they have a half moon look to them
GUIDO
02-25-2013 14:37:49
 Re: Sharpest knife you have? in reply to old, 02-25-2013 13:33:32
Hello old,
Got some of them too, brokem in pieces and dips and vallies.
Guido.
old
02-25-2013 15:10:12
 Re: Sharpest knife you have? in reply to GUIDO, 02-25-2013 14:37:49
One thing I have to tell many people is to keep there fingers off the blade when I sharpen a knife. Many like to run there fingers across the blade to check them and I then in turn say give it back to me so I can not fix what you just messed up. When I do that they just like at me and say what. Learned years ago your finger tips have enough acid etc in them to take the edge off the blade the moment you touch it. But then I was taught to sharpen knifes by the son of a guy who did the scalpels used in hospitals years ago
da.bees
02-24-2013 20:19:37
The only knife I bring to shaving sharp is one blade of the case trapper carried only while hunting. Most every thing else is sharpened with more bevel and only touched up enough for the intended task.
