J B weld-will it work?
farmerjohn
I have an air compressor that my cat knocked a tool box off the shelf and hit the compressor and sheared off the nipple that the regulator was screwed onto. I got the nipple stud out and replaced but where it threads in the aluminum casting cracked and a small chunk came off and it leaks air. Have not found a replacement part, can I reattach the piece with J B Weld and will it hold good enough? I never used it before.
