Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Re: Add on tankless water heater
[Show Entire Topic]  [Return to Forum]
da.bees
02-23-2013 08:55:37
72.181.183.240
I'm suprised to hear so many complaints about irregular water pressure and noone useing a whole house booster tank and pump. Lower cost boost pump alows lowering wellhouse pressure which extends expensive well pump life and saves enough electricity to run the booster pump. I never gave much thought to this until I saw a very clever set up on a place where he had a problem with running his well dry during peak water usage. Seems he had a constant year around stream to the well but it was at a low rate of flow. He had a large elivated tank that was filled in 24 hour timed intervals. He said pump maintainance dropped dramaticly when the pump no longer pumped against pressure. He had some gravity fed outdoor hydrants and booster for the house. They said there was an unexpected benifit when power went off as it often happens during storms,they still had running water albeit gravity fed.
[Reply]   [No Email]
JD Seller
02-23-2013 20:09:10
208.126.196.144
da.bees: The issue is not the well pump having problems pumping it is how the systems work. A well with a pressure tank will have a 20 PSI low to high range. That is just how they work. An example of this is my system it kicks the pump on at 40 psi and off at 60 psi. The flow changes over the the pressure range. My well was tested at 100 gallons a minute flow. So water supply is not an issue.
A private tank system is a problem in cold climates. Plus you need a tall tank to have much pressure. Years ago they would have tanks up on the windmill towers in the warmer areas. Also you have a problem keeping stored water fresh. That is one reason public water is treated.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
