TractorLinks.com
Tool Talk Discussion Forum
Re: OT foundation crack
George Marsh
02-20-2013 12:05:11
The house in the pic was built in 1968. I was digging a footer for a room addition when I discovered a crack in the block going all the way down. I'm guessing the crack developed when the basement was backfilled. The basement is finished and can't see what the inside looks like. Going to guess when the south wall cracked because the trusses put all the weight of the house on the outside walls and there was no weight on the wall that moved. Also bet there is a has to be more than one crack. I used a pressure washer to clean out the crack and then fill the crack with motar.
The best way to stop a basement from leaking is to prevent the water from getting there in the first place, gutters and angle the ground so the water runs away from the house. If all else fails, remove the dirt from the side of the house, fill the other cracks, seal the wall, put in a drain and then back fill by hand. George
MSD
02-20-2013 16:11:38
 Re: OT foundation crack in reply to George Marsh, 02-20-2013 12:05:11
Back filling would have pushed the wall in not out unless I am not looking at the picture right.. Also, it doesn't happen in a corner like that. Usually you see a crack start in the middle of the wall if it is from backfilling.
George Marsh
02-20-2013 17:09:35
 Re: OT foundation crack in reply to MSD, 02-20-2013 16:11:38
MSD,
You are looking at it wrong. The first pic is the south wall which was pushed in. The second pic is the west wall, load bearing wall. The top block didn"t move. The corner cracked open, hinging off the inside of the west wall blocks.
Yes, there has to be at least one or more cracks on the south wall, but not visiable because the basement was finished.
Because the ground is clay, and the dirt is angled away from the house, the only time water gets in the basement is if someone watering her flowers leaves the hose running and forgets.
If the basement was wet all the time, you can rest assured I would dig it out with the backhoe, fix the problem, back fill with sand, put heavy plastic down to act as a roof to deflect water away from house.
I fixed the crack 3 years, so far, no problem.
George
MSD
02-20-2013 18:04:42
 Re: OT foundation crack in reply to George Marsh, 02-20-2013 17:09:35
I see what your saying now. Top block probably has an anchor bolt holding it. Still odd to see it take a corner out like that. Any I have ever seen that pushed in just cracked in the middle and the fact it went all the way to the bottom makes me still wonder if something else happened. Was the footing cracked also?
George Marsh
02-20-2013 18:14:39
 Re: OT foundation crack in reply to MSD, 02-20-2013 18:04:42
NO crack in footer, it was caused by the south wall getting pushed in.
