Compressor 1940
Janet Fraser
New User
1940 Air compressor
Jansen Marine automotive Salem Ma
Original label brass built in salem ma
value of piece it is still running
There should be a nameplate on the motor. It would be best if it could make good pressure and not have a worn out piston[or two]. Someone here will help you. This is a very good tool site.
this is a photo of the Compressor
I have bought similar compressors for 100 dollars. It has to make pressure . The electric motor looks updated so probably if it was worth getting a new motor for it and so would indicate the head is good and makes good pressure.If they don't ever get drained the bottom of the tank will start to get pinholes as it rusts from the inside out.Nice size tank.
