| Tool Talk Discussion Forum |
Topic: Lincoln AC/DC
[Return to Forum]
| Author |
[Modern View]
| bobpa
02-18-2013 14:34:17
96.236.176.180
I just got a new Lincoln AC/DC 225/125 for home use. Why is the duty cycle only 20percent on all taps? I thought that was the rating if maxed out. With my Miller I usually forget about a duty cycle and just weld until done with no problem. 20 percent doesn't seem like much welding and alot of waiting. Hope I didn't make a mistake. |
| mkirsch
02-21-2013 06:50:54
64.80.110.75
Re: Lincoln AC/DC in reply to bobpa, 02-18-2013 14:34:17
| I don't think the 75 Amp setting is 100% duty cycle anymore.
My early 1970's era tombstone has the 75A setting circled, but new ones at Home Depot do not.
Lanse has a Longevity Stickweld 250 which has a 100% duty cycle up to 200 Amps if I'm not mistaken and 60% at 250 Amps. It's around $500, so not much more than a Lincoln AC/DC tombstone. It's made in China so if that's a problem for you it may not be an option.
My Lincoln has been pushed way past the 20% duty cycle on many occasions over the last 40 years and it's still kicking. The only problem it's had is the cooling fan went bad. I replaced it with a large 220V muffin fan from Mouser Electronics. |
| bobpa
02-22-2013 15:34:32
96.236.180.128
Re: Lincoln AC/DC in reply to mkirsch, 02-21-2013 06:50:54
| Thanks for the info. Good to know it seems alot of fellows say they are able to handle more than the 20 percent duty cycle. Ive read the owners manual and found it has a breaker protector for DC welding but not AC. So I guess if I push it too hard it will just shut off on DC. I see Lanse using the Chinese welders but can't bring myself to buy one. Thanks Bob |
| Stan in Oly, WA
02-19-2013 11:26:12
174.31.223.173
| | Bob, If you open a Lincoln welder like the one you bought, you will see that the different amperage output settings are achieved by tapping different locations on the transformer with individual conductors which run to separate connection points on the back of the selector switch. Part of the reason that this welder has only a 20% duty cycle at every setting (except for the 75 amp setting which is 100%), is that the conductors are not all the same size. They run from the smallest conductors at the lowest settings to the largest at the highest. Since the duty cycle is a function of the amount of heat which is generated during use, using conductors which all generate approximately the same amount of heat per unit of time creates a situation where lower amperages do not result in a corresponding increase in duty cycle. The situation is actually somewhat more complicated than I have described (a more complete explanation can be found in the archives of this site), but it is reasonably accurate---at least in its result. Lincoln 225 amp AC and AC/DC welders are famous for robustness. Many, many people report using them without regard to the duty cycle with no problems. While I wouldn’t go so far as to recommend that approach, I think you’ll find that the 20% duty cycle won’t pose a limitation for regular usage. Stan |
| bobpa
02-19-2013 11:39:48
96.236.176.180
Re: Lincoln AC/DC in reply to Stan in Oly, WA, 02-19-2013 11:26:12
| Thank you for the information Stan. I appreciate your help. Bob |
| bobpa
02-19-2013 10:19:24
96.236.176.180
| OK thank you everyone. I guess what threw me was the 20% duty cycle on all settings. I always thought as amperage goes up duty cycle goes down. And since I never need bigger than 1/8 rod for home figured I'd have plenty of duty cycle to work with. Anyway, I know they have a good reputation for durability and I feel better after listening to you all. Thanks for your help. Bob |
| Stick welding
02-18-2013 21:57:08
96.53.210.246
| I wouldn't worry too much. I doubt you'll be using big rods but just do a weld, chip the slag and then do another weld. This will give a little cooling time between rods. |
| Inno
02-18-2013 19:12:56
70.49.154.245
| For home use you should be just fine. I have the same welder and I've welded for long periods of time at fairly high settings without any trouble. |
| welding man
02-18-2013 14:52:32
76.9.225.68
| I'd say you got what you paid for.100% duty cycle machines are expensive.60% aren't cheap.I would say it has aluminum windings. I'd weld with it like I stole it, It should have a warranty. If it dies take it back. |
| Bob Bancroft
02-18-2013 14:45:06
97.73.64.149
| I have one I have used for general farm repairs for at least two decades. It has worked fine. But, I use mostly Lincoln 6011 1/8". 90-100A. It seems to be "hot" and not take as much power as some others. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
