Parts Washer Shopping
Anonymous-0
Who makes a decent parts washer suitable for a home shop? I figure 20 gallon would be a good size. I plan on mineral spirits or kerosine for solvent.
Thank you,
Glenn F.
I can not say who makes a good one but if you use what your think about in them unplug it do not use the switch to turn the pump off because you stand a good chance of having a fire. Guess how I know that one LOL. Yep turned off my parts washer pump with the switch and had me a nice hot flash fire in it
(quoted from post at 02:58:18 02/16/13) Who makes a decent parts washer suitable for a home shop? I figure 20 gallon would be a good size. I plan on mineral spirits or kerosine for solvent.
Thank you,
Glenn F.
The best are Safety Kleen,,, Are advertize you are looking for one on Craigslist... I have been using a SK unit for 33 years on a daily basic and never had ONE issue with it...
http://s-kstore.com/index.php/sink-parts-washer-model-30.html?SID=3580e1493e41397f646a598429956508
I use the type that sets on a drum.
Used ones go for 1 to $200 I use the 30 gal model they also have a 20 gal...
They are EZ to service (as were the HF junk is a PITA to service),,, the Big'n is worth the extra money it will be the last one you will ever by...
Edit one last time,,, I fill the drum up with water are use coolant to about 3 to 4" to the bottom of the pump then add 10 gal of varlsol...
We used to use solvent tanks too. They did the job ok. We now use a CUDA. Top shelf water based cleaner. We can put in a small block w/o the heads, turn it on and walk away. It frees you up to do other things. They are kinda pricey, but worth it for the busy individual. I wouldn't part with mine/ours. Gerard
Bought a new smart washer by chem free. It works great. No flash point. Easy on hands. Cleans good. But it is pricey
