| Tool Talk Discussion Forum |
Topic: Need to rig up something...
[Return to Forum]
| Author |
[Modern View]
| Diydave
02-14-2013 16:26:32
96.244.162.208
Some ijit ran down a sign I made out of some farm junk, and I need to make a patch, does anyone know what the ID of a 4" schedule 40 coupler is? I need about 4-1/2" to 4-5/8" ID, to slip over the broken ends of the signpost, and attach all together with set screws. If it's a little tight, I can turn the ID to what I need, if it has thick enough side walls. Any other pipe out there, with a 4-1/2" ID?? |
| Diydave
02-15-2013 16:02:06
96.244.162.208
Re: Need to rig up something... in reply to Diydave, 02-14-2013 16:26:32
| I think I got 'er licked. Stopped by my friend, the starter and generator rebuilder, gonna try a generator housing. Gotta take the core apart, to see if she'll fit! I did hammer in 2 half t-posts, right into the wheel tracks, where the SOB backed up the bank, to KO the sign post. I cut them at a 45 degree angle, so they WILL flatten tires! |
| welding man
02-15-2013 15:08:06
76.9.225.68
| Probably can't find one too easily but a 4 in socket weld coupling would work nicely. |
| KLS
02-15-2013 13:20:10
66.241.134.40
| A regular 4" pipe coupling should be about perfect for you, to buy pipe to fit would be very expensive. |
| jackinok
02-15-2013 06:38:21
162.58.82.136
| shcedule 40 plastic ,4.5 inches od with a wall thickness of .237" steel pipe, has the same od, but the wall thickness varies by the wt of pipe . std wt black/galv pipe is the same as schedule 40 pvc IF you use a threaded steel/sch 40pvc threaded coupling,turning the threads out should make a slip coupling. if this is what you need,and its strong enough, a sch 40 glue coupling should slide over either snuggly. problem may be putting your set screws in a pvc coupling. even though its very easy to tap, threads would strip easily. in that case,or if its a problem, a schedule 80 pvc slip coupling would have thicker sidewalls but the same id,IF you could find one of course. most normal pvc couplings will have a stop inside, if thats a problem look for whats known as a slip/repair coupling its exactly the same without the stop. hope this helps! |
| Cliff Nelson
02-14-2013 20:57:43
69.21.97.161
| OD of 4 inch pipe is 4 1/2 inches so you could bore the threads out of a coupling to get what you need. |
| george md
02-14-2013 19:14:37
209.213.167.201
| Dave , How thick and how long ? I have a 7" dia piece of cored stock with 3" hole , can bore to fit. george |
| Diydave
02-15-2013 05:33:08
96.244.162.208
Re: Need to rig up something... in reply to george md, 02-14-2013 19:14:37
| Thanks for the offer, George. I think I can find the coupler local. Have you ever seen a tobacco prize screw? That is what I'm using as a signpost. Can't weld it at the end of the driveway, AND it's cast iron! Whoever did it, will be in for a surprise, if they try it again, I have some sharp improvements ready for them! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
