TractorLinks.com
Tool Talk Discussion Forum
Re: 2002 Goodman Dependable 92
Roger Tomfohrde
02-07-2013 16:51:59
Usually that piece is part of the secondary heat exchanger on most furnaces. They are changed out with the secondary, especially in Trane. You may be able to get the part but I'm leaning to the not possible. Is the crack leaking the condensate out into the inside of the furnace,probably, if so wash it out immediately as it is corrosive. J-B weld or a good high temp silicone could possibly patch it for the short term. If this furnace was purchased new by you, you may want to check to see if there is warranty on the secondary. Even so it is getting old enough that you may be adding money to something that is ready to fail in other ways. My biggest question is where is the condensate going if not into the drain. There may be more wrong than the cracked collector box.
