Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Simpson 150 Amp Clamp
[Return to Forum]
olilt
02-07-2013 13:14:26
68.56.185.101
I obtained a Simpson 150 Amp Clamp as part of an estate. The included instructions indicate that this tool was originally intended to be used with an analog AC instrument with a sensitivity of 5000 ohms per volt containing either a 2.5, 3, or 5 volt scale. There is a multiplication factor that is then used to calculate the total amps depending on the volt scale used.
Can this tool be used with a digital multimeter? The scales on my meter are much broader that 2.5, 3, 5 volts AC.
[Reply]   [No Email]
olilt
02-07-2013 19:31:52
68.56.185.101
 Re: Simpson 150 Amp Clamp in reply to olilt, 02-07-2013 13:14:26
Ok, I'm beginning to get it. Just one clarification: should the resistor, or potentiometer be in series or parallel with the meter leads. Thanks for your response.
[Reply]  [No Email]
tech4
02-08-2013 07:26:50
72.15.69.60
 Re: Simpson 150 Amp Clamp in reply to olilt, 02-07-2013 19:31:52
Yes it should be in parallel. Or as suggested find a Simpson 260 or Triplett 630 or 310.
The Simpson has a 2.5 volt scale and Triplett has the 3 volt scale.
I still love my old Simpson 260 except when I need a precision measurement. I like to see that meter swing!
[Reply]  [No Email]
MarkB_MI
02-08-2013 02:52:32
75.198.76.165
The shunt is in parallel with the meter leads. You're lowering the input impedance of the multimeter so it looks like it's an analog voltmeter. If possible, get a precision (1%) resistor. Radio Shack resistors are typically 5%, which is enough to affect the accuracy of your readings.
[Reply]  [No Email]
john *.?-!.* cub owner
02-07-2013 19:23:44
69.179.164.25
The simplest thing would be to find an old Simpson 260 meter and use it. Or a better idea may be to go on Ebay and buy one of the new digital AC/DC amp clamps for around $25.
[Reply]  [No Email]
olilt
02-07-2013 18:10:32
68.56.185.101
I am getting lost in the discourse. Suppose I set my DVOM to the 2 volt scale. What do I need to do to?
[Reply]  [No Email]
tech4
02-07-2013 18:54:25
72.15.69.60
 Re: Simpson 150 Amp Clamp in reply to olilt, 02-07-2013 18:10:32
You will have to do some interpolation. Your digital meter should have a high input impedance and be a negligible load. You could use 2.5 as full scale but you would need a 12500 ohm resistor which is not common. 15000 is very common and you would use 3 volts as full scale. The scale on your digital meter should make no difference as long as it is above 3 that is 10 or 20 vac.
For instance on the 300 amp scale the meter would read 3 volts or 200 amps will read 2 volts.
On the red 12 amp scale the multiplier is 4 and 3 volts = 12 amps of 2 volts =8 amps and so on
If I was doing it, I would use a 20K potentiometer and place across the meter leads and calibrate the reading to match the reading of a known good meter.
[Reply]  [No Email]
Ted in NE-OH
02-07-2013 14:54:07
72.16.19.80
Tech4 you are right, I stand corrected
[Reply]  [No Email]
Ted in NE-OH
02-07-2013 13:59:19
72.16.19.80
Yes, if you shunt the input to the DVM with a 5000 (5K) resistor.
[Reply]  [No Email]
tech4
02-07-2013 14:23:00
72.15.69.60
 Re: Simpson 150 Amp Clamp in reply to Ted in NE-OH, 02-07-2013 13:59:19
That is 5000 ohms per volt. To use the 3 volt scale you would need 3 X 5000 or 15000 ohms (15K)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
