| Author |
[Modern View]
| jCarroll
02-06-2013 11:40:22
75.22.113.218
I want to build a clock using old barn lumber for the face - maybe 4 or 5 feet in diameter. To go on our stone chimney above the fireplace. AC power is available.I've contacted one clock company, and their best offering is a battery motor which would operate a 24" diameter works. Anybody got leads on where I could get a motor/mechanism for a clock of this scale. Thx in advance. |
[Reply] [No Email] | |
| glennster
02-07-2013 10:03:40
76.223.253.108
Re: motor for a reallly big clock ? in reply to jCarroll, 02-06-2013 11:40:22
| wonder if you could find a clock from the old standard gas stations. they used to have a huge bill board with a clock on it, prolly 6 0r 8 feet across. |
| PAGlenn
02-06-2013 15:50:26
69.142.233.106
|  This brass clock movement was in the tower clock of a tall building in Riverside NJ. Someone stole it years ago, and it was found a few years back and now resides in the town museum elevator which is in the tall building in Riverside. |
| Chris(WA)
02-06-2013 15:20:22
64.38.158.247
| Here is a link to the size movement you are looking for. |
| jCarroll
02-06-2013 16:58:49
75.22.113.218
Re: motor for a reallly big clock ? in reply to Chris(WA), 02-06-2013 15:20:22
| | This looks exactly like what I had in mind. Thanks for what I learned today (tower clocks). jC |
| jCarroll
02-07-2013 07:42:37
75.22.113.218
Re: motor for a reallly big clock ? in reply to jCarroll, 02-06-2013 16:58:49
| | And what I learned today is ................. the movement and hands for a 4' clock will be about $950 might have to sell a tractor - NOT |
| D7fever
02-06-2013 14:06:09
72.79.198.121
| You will need a whole movement, for a like a tower clock. I used to service, sell , install that type of clock. The last link to American time, will probably get you right stuff. the movement will probably be 10 -12 inches or so, going to have to have room for it. Good luck. |
| Steve A W
02-06-2013 13:22:39
71.201.150.15
| | Here's another clock suplier. Steve A W |
| Steve A W
02-06-2013 13:27:23
71.201.150.15
Re: motor for a reallly big clock ? in reply to Steve A W, 02-06-2013 13:22:39
| And another. |
| GUIDO
02-06-2013 13:02:46
71.168.254.186
| | Hello jCarroll, Here is a link for you. If you don't find it there, you can call them @ 1-800-328-8996, Guido. |
| Diydave
02-06-2013 16:16:04
96.244.162.208
Re: motor for a reallly big clock ? in reply to GUIDO, 02-06-2013 13:02:46
| Why not just gear down an AC motor, it's just a math problem! |
| Rich_WI
02-06-2013 16:23:12
50.50.77.31
Re: motor for a reallly big clock ? in reply to Diydave, 02-06-2013 16:16:04
| Quoting Removed, click Modern View to see
If the OP is going to go that route, I would think it would work better to run something like a DC motor so if the clock is fast or slow, the RPMs could be adjusted to correct it. |
| Jean-Raymond
02-06-2013 23:25:22
70.82.173.21
Re: motor for a reallly big clock ? in reply to Rich_WI, 02-06-2013 16:23:12
| You cant just gear down. You need a speed regulator, something like a governor. Because ,if not,any small change in the voltage or even in temperature, will modify the speed. |
| Mammie
02-07-2013 02:38:09
70.109.162.54
Re: motor for a reallly big clock ? in reply to Jean-Raymond, 02-06-2013 23:25:22
| 12:00 BLINK 12:00 BLINK 12:00 BLINK 12:00 BLINK 12:00 BLINK 12:00 BLINKwho's gonna reset this thing gonna take a big roll of black tape to cover that |
