Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: dust extractor
hd6gtom
02-06-2013 07:36:48
Guys Thanks for the replies, as for the ground wire does it just lay in the pipe, fastened on the collector end, or does it need to come in contact with both machines when they are running. As for cost of the equiptment I want it to last the rest of my life. I am not too concerned with the cost up to $4000.00 on the saw. Is the Saw Stop machine accurate, that is my main concern, I have not seen 1, but I have seen all the rest mentioned.
evilboweivel
02-07-2013 15:59:32
 Re: dust extractor in reply to hd6gtom, 02-06-2013 07:36:48
" as for the ground wire does it just lay in the pipe, fastened on the collector end, or does it need to come in contact with both machines when they are running"
use a bare copper wire inside of all plastic pipe
solder all joints
have the wire(s) exit a hole in the side of the pipe and go to a ground rod(s) driven 6+ feet in the ground
does not need to connect to the machines as all the machines should be grounded properly thru the equipment grounding conductor back to the main panel
GOOD LUCK
Ron
Copyright © 1997-2015 Yesterday's Tractor Co.
