TractorLinks.com
Tool Talk Discussion Forum
Re: Baldor Capacitor size
GUIDO
02-05-2013 15:48:20
Hello 4020guy,
Buickandeeere is correct on both counts.
However MFD's increase should be limited to about 20%
Guido.
missouri massey man
02-13-2013 07:36:31
 Re: Baldor Capacitor size in reply to GUIDO, 02-05-2013 15:48:20
I thought start capacitors could be varied by ten percent and only run capacitors could be varied by twenty percent. Start caps typically being high in mfd whereas run capacitors are typically low in mfd. Memory may be a bit fuzzy though. I was thinking this motor is a motor with dual start capacitors, and capacitance being additive in parallel the total capacitance can be varied by ten percent. Let me know if I'm wrong, I don't want to be spreading incorrect info. The voltage induced in the start windings is typically much higher than the applied voltage, which is why you need 370v rating on a 240v motor. Too high on the start winding capacitance will eventually damage the start winding is what I was taught back in the day.
Are the capacitors bad, or do they just look bad. Many digital volt ohmeters have a capacitance scale that can be used to read the mfd ratings on a good capacitor. If one is good and you have the meter to read it, both will be the same size on a dual capacitor start motor.
Hope this helps you and want to be corrected if my memory is wrong.
