pulling engin sleeves
luapp
how do youes usaly remove engin sleevs? ive always beat on a stick but id like a puller but dont know where to get one thanks
I made a puller for pulling sleeves from my Oliver. I bought a fine thread 7/8 bolt, Then just put holes through two stout pieces of steel and started tightening. You need a lot of pull and thus heavy stock to break them loose, Then you can switch over to a lighter piece for underneath, that will just clear the bore. On top you can add spacers under your heavy piece as it comes up and out. You don't need fancy.
(quoted from post at 05:33:17 02/01/13)
I have found that on bolts of the same size that find threads seam to strip quicker than coarse threads.
Dusty
Did the same thing; only problem is, I could probably make a new one quicker than I could find the old one.
If you're handy with metal you can make a puller like Keith made for his Super C. He made a puck that was machined .010-.015" undersize to fit the inside bore of the sleeve and enough clearance to clear the block bore. Hal
Untitled URL Link
I've got a Snap-On sleeve puller, that has about
8 sizes of puller pucks. It cost over $200, in the
late 1970's,and is probably over $500 now. For me,
it has pulled hundreds of sleeve, and was worth
the investment.
My worthless grandsons wouldn't even know what it
is and would probably pawn it for $25, and buy
video games, when I pass!
For wet sleeves I have the OTC 1205 puller. It is not cheap at $500+ but well worth it if you're in the business.
I've not been into a diesel before but I've heard folks talk about welding vertical strips up the sleeves so they just lift them out after they cool.
