| Tool Talk Discussion Forum |
Topic: welding cast
[Return to Forum]
| Author |
[Modern View]
| craigco
02-01-2013 16:52:36
69.171.160.198
The window latch in my trackhoe is made out of cast. The shop mechanics replaced the glass and managed to break the latch. No the window is a pain to open have to use a screw driver to wiggle the latch to open it. Can't replace just the latch as it was asssembled into the frame, you have to replace the entire frame. what are the chances of welding a peice on to the latch. I can,t move the trackhoe to a stick welder but I have a little mig that my generator will power. Think it will work or just a waste of time. I would like to be able to shut it to keep the weather out. |
| GeneMO
02-04-2013 15:57:44
71.1.106.8
Re: welding cast in reply to craigco, 02-01-2013 16:52:36
| | I would bet it isn't cast iron. Maybe a cast, mallable steel. If it's a "pot metal" type stuff, forget it. Maybe cast aluminum. Gene |
| Jo Bird
02-02-2013 09:15:43
65.37.25.4
| The one thing no one has mentioned is, glass, is NOT very tolerant of heat or sparks from welding, has something to do with, rapid expansion. LOL. Shield the glass as best you can or you may double the cost of your repair buying another window. |
| craigco
02-02-2013 04:32:31
69.171.160.159
| It is broke even with the frame. When you pull it down it rotates about 1/2 inch out. So I can,t bolt it. It is on a cat 330b I will try to weld it Monday, If that doesnt work I will JB weld. Thanks |
| RodInNS
02-01-2013 21:33:48
216.118.158.123
| | If it's cast iron you're probably better off trying to braze it given your circumstances. If it'ss cast steel it should weld OK with the mig. I'd expect it to be steel if it's a cab part... but you never know. Determine what it is first... Rod |
| Mel in SW Iowa
02-01-2013 17:44:39
75.105.35.117
| Is it thick enough to drill a hole or two into and tap for a 1/4" bolt to repair the fracture? |
| Chris(WA)
02-01-2013 17:20:01
64.38.158.247
| Cast what? Most of the cast latches today are aluminum or phenolic resin not iron or steel. Neither of which are readily weldable. The JB weld idea might work. Post a picture of the two pieces. Someone will have an idea. |
| D7fever
02-01-2013 17:06:56
108.8.200.103
| Might have better luck with JBweld |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
