TractorLinks.com
Tool Talk Discussion Forum
Re: Slit tubing?
Frank (N.Mi.)
01-29-2013 15:18:21
Ok, yeah thanks for answers so far-- I wasn't really thinking right when I posted the question...The heavy rubber hose trick may work OK but I'm wondering if it is possible to get some metal slit tubing in those sizes? I probably need about seven feet. Not sure if plastic is gonna be durable enuff it will be subject to vibration and maybe a bit of heat
Dusty MI
01-30-2013 06:20:53
 Re: Slit tubing? in reply to Frank (N.Mi.), 01-29-2013 15:18:21
How about having it made out of sheet metal on an 8 foot brake?
Dusty
Dick L
01-29-2013 15:31:39
I don't know where you can buy it already slit but if I were needing it I would slit it this way.
I would clamp the tubing to a sheet of plywood. Then make a carrier on wheels to hold a dermal or die grinder. Choose a cutting wheel the thickness I needed, fasten some runners to make sure the cutting wheel was on center of the tubing. I would then run the cutter wheel the distance of the tubing making a shallow cut then lower it a small amount for each pass until it was slit all the way thru.
The most time would be in the setup. Much like most of my tooling jobs I do.
