Geo-TH,In
Old, found a pair of diodes, IR 28-14-016 8603 mex f5. Couldn't find any info on them. The anodes has 2 10g wires attached to them. I've used 3 in parallel to repair my old mig. You would have to mount both diodes on the same aluminum heat sink and insulate the sink from the frame of the charger.
Double check, I'm 99.9% sure the 2 anodes go to the transformer wires and the 2 cathodes are the + out wire.
If you need these diodes I'll give them to you. I'm leaving my email open.
George
George
