Oxygen Bottle Replacement
super99
Just wondering, do you use your torch until the oxygen bottle is totally empty, or do you replace it when the guage reads 0? I finished heating some parts to disassemble the other day, and the guage for the high pressure reads 0, but the low pressure guage still has a reading. I know it won't run very long this way, If I start on something bigger, I know it will run out, but I could get a couple of little jobs out of it yet. I will probably run it clear empty before picking up another bottle after work. Just wondering what you all do. Chris
Why? If you run out, you run out. Oxygen not a big deal but with some cylinders, especially shielding gas, you don't want to run out in the middle of a weld. Usually on shielding gas cylinders you replace them when the pressure is below 100 PSI. There are some cylinders that say on them to leave at least 25 PSI in. I think it's so they don't get contaminated but the proper procedure for filling cylinders, especially argon, is to purge the cylinder before filling it so you are guaranteed 100% pure argon. It is very noticeable when welding aluminum if you have dirty argon. Sometimes the guy filling it is in a hurry or too lazy to purge the cylinders. Cylinders are also routinely switched from one type of gas to another.
I paid for a all the argon, gas or oxygen that is in a bottle.
So I use it all.
Like I'm gonna ever get back a bottle that I returned again so why worry about leaving some in it.
Gary
I have 2 Oxygen bottles & 2 Accetelyne bottles + 1 Argon . I asked my AIRCO supplier that question & he said I paid for a full bottle so use it all , why waste any . So, empty the bottles because when I return them, the dock guy right away opens the valve himself & blows it out anyhow . The company demands he returns a completely empty bottle for refilling . Also I learned that whenever using Oxy or Accety or Argon , the valves must be opened completely because the seals don"t accually seal off if not turned completely opened or closed . Before, I was concerned about smelling fuel when I was using my torches & mig ; so that"s why . HTH ! God bless , Ken
High pressure cylinders are supposed to be fully opened to seat properly but ACETYLENE SHOULD NEVER BE OPENED MORE THAN 1 1/2 TURNS!!! YES, I'M YELLING! That's O/A safety 101! It sounds like your supplier isn't too sure about things. The Airco gas business was bought out by BOC several years ago and the company is called Linde. Cylinders should be bled off in a controlled environment, not at the dock of the welding supply. Having a little pressure in the cylinder is a good thing.
Inert means it's chemically inactive and doesn't have any chemical reactions. CO2 on the other hand isn't an inert gas. Argon is heavier than air and can fill up in your lungs. TIG welders working in closed spaces will stand on their head after finishing welding to let the argon out of their system.
Well since you YELLED AT ME ,I'll just yell rite back . I ONLY STATED WHAT MY SUPPLIER TOLD ME . But I will definitely confront him again about it . I never heard that Airco sold out to Linde . My shop account is under the Airco name & payments go to Airco .But now I'm curious . If I don't forget when I go out for another refill , I'll ask him that also . I do know ever since this guy started running this supply store , he's layed off , & fired people . Now he himself manages the business & does counter sales , & dock work by himself .When he gets busy , it takes more time to get my counter business done & to get out of there . This guy was originally with GOSS Gas , another local supplier run by his brother who surprisingly has the last name of GOSS . They said he got tossed out due to his self centered method of running the family business . So apparantly that statement was true . I have troubles with a Know-It-All myself . So I just accept some of what he says . God bless, Ken
Stick welding is correct. The oxygen/shielding gas cylinders have double seat valves that seals on top and bottom. I have 6 oxys, 3 acetylene, 1 argon, 2 75/25s, 1 90/10, and a 100 lbs of propane. I generally remove my cylinders from service when my high pressure the same as my working pressure.
I was intending to yell at you Ken, just in general so one else follows this practice because the first thing you learn in O/A safety is to never open the acetylene very far in case you have to shut it off in a hurry. If your cylinder uses a key always leave it in place for this purpose. Yelling at your supplier for giving you this wrong info about acetylene might be in order though. It wasn't just wrong info, it was dangerously wrong. Your welding supply could be called Airco and have nothing to do with the old Airco brand name/trademark. Airco was very big in O/A and formed a division that originated many cutting machines, including the Radiagraph, Camograph and pipe cutting machines. They also held the first patents and introduced MIG welding in 1948.
I will definitely mention it to the guy at Airco next time out . I appreciate the info . I'm definitely not what you'd call a welder but do enjoy the challenge & experience learned . I'm only a hobbiest doing my own repairs . I definitely don't profess being a know it all . I'm enjoying plus wanting to learn & I do learn new things daily . God bless , Ken
Look in a manual that comes with a torch set. I'm almost certain it will state not to open the acetylene more than 1 1/2 turns. If it doesn't, you can refer to the oxy/acetylene handbook put out by Esab.
I agree, but tend to dissagree with you. If you check, you will find every answer from 1/4 turn to 1 1/2 turns. The purpose of only opening the acetylene valve a short distance is so it can be closed with a twist of the wrist. When I was teaching welding it was 1/4 turn. We also taught that you never drained the acetylene pressure down all the way as it would let the acetone drain off possibly creating a void in the suspension material. The gas acetylene will become self explosive at 29.4 p.s.i. At least that's what we taught in the 70s & early 80s. things might have changed from then to now. Just my thoughts, Keith
(quoted from post at 17:57:57 01/27/13) If you inhale a big lungfull of Argon does it make you talk like Donald Duck?
No, you will sound like Darth Vader, and then you will suffocate.
You actually have to "dump" the gas from your lungs by getting your lungs higher than your mouth.
Back in the mid 70's we were taught to open the acetylene valve 1/4 to 1/2 turn......but.....there were B tanks (40 CF) that used a double seat valve.
When I bought my torch back in 1979 I was told to only open the A one full turn and the O full open. Also was told never run the A down to less than 25# because it would damage the cylinder. The O all it will do when it is run empty is the high heat will stop and just the A will keep on burning. Have had that a few times. Just used for farm repairs.
I generally run my O2 down until it can't sustain a neutral flame for whatever I'm doing. Then I change out the bottle. That will usually leave me with ~30 PSI in the bottle.
Generally speaking you should never bleed a bottle of any type completly empty. The reason for this is that a bottle at atmospheric pressure will form condensation on the inside of the bottle which then pools as water in the bottom... and forms rust... which is not good in a cylinder. At long as you maintain the pressure somewhat above atmospheric pressure it's not going to condensate, at least not as much.
If the supplier then wants to empty or purge the bottle, that's up to them... but ast least it's being purged and refilled right away so it remians under pressure most of the time.
Rod
I said never open more than 1 1/2 turns but usually about 1/4 turn is enough. Somevalves have to be opened more though.
I should have added that unless you're using a rosebud, you usually get too small of flame before the acetone will leak.
I have 2 sets of bottles so run the bottles completely empty then go get them filled.
It never failed that I would run out of gas in the middle of a project when the store is closed.
