| Tool Talk Discussion Forum |
Topic: Re: Oxygen Bottle Replacement
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Stick welding
01-27-2013 18:25:39
96.53.210.246
High pressure cylinders are supposed to be fully opened to seat properly but ACETYLENE SHOULD NEVER BE OPENED MORE THAN 1 1/2 TURNS!!! YES, I'M YELLING! That's O/A safety 101! It sounds like your supplier isn't too sure about things. The Airco gas business was bought out by BOC several years ago and the company is called Linde. Cylinders should be bled off in a controlled environment, not at the dock of the welding supply. Having a little pressure in the cylinder is a good thing. |
[Reply] [No Email] | |
| Keith Molden
01-28-2013 05:37:08
167.239.222.80
Re: Oxygen Bottle Replacement in reply to Stick welding, 01-27-2013 18:25:39
| I agree, but tend to dissagree with you. If you check, you will find every answer from 1/4 turn to 1 1/2 turns. The purpose of only opening the acetylene valve a short distance is so it can be closed with a twist of the wrist. When I was teaching welding it was 1/4 turn. We also taught that you never drained the acetylene pressure down all the way as it would let the acetone drain off possibly creating a void in the suspension material. The gas acetylene will become self explosive at 29.4 p.s.i. At least that's what we taught in the 70s & early 80s. things might have changed from then to now. Just my thoughts, Keith |
| Stick welding
01-28-2013 10:57:35
198.53.25.107
Re: Oxygen Bottle Replacement in reply to Keith Molden, 01-28-2013 05:37:08
| I said never open more than 1 1/2 turns but usually about 1/4 turn is enough. Somevalves have to be opened more though. |
| Stick welding
01-28-2013 11:02:18
198.53.25.107
Re: Oxygen Bottle Replacement in reply to Stick welding, 01-28-2013 10:57:35
| I should have added that unless you're using a rosebud, you usually get too small of flame before the acetone will leak. |
| Leroy
01-28-2013 09:04:19
69.88.205.38
| When I bought my torch back in 1979 I was told to only open the A one full turn and the O full open. Also was told never run the A down to less than 25# because it would damage the cylinder. The O all it will do when it is run empty is the high heat will stop and just the A will keep on burning. Have had that a few times. Just used for farm repairs. |
| Ken-Pa
01-27-2013 18:50:00
75.179.10.67
| Well since you YELLED AT ME ,I'll just yell rite back . I ONLY STATED WHAT MY SUPPLIER TOLD ME . But I will definitely confront him again about it . I never heard that Airco sold out to Linde . My shop account is under the Airco name & payments go to Airco .But now I'm curious . If I don't forget when I go out for another refill , I'll ask him that also . I do know ever since this guy started running this supply store , he's layed off , & fired people . Now he himself manages the business & does counter sales , & dock work by himself .When he gets busy , it takes more time to get my counter business done & to get out of there . This guy was originally with GOSS Gas , another local supplier run by his brother who surprisingly has the last name of GOSS . They said he got tossed out due to his self centered method of running the family business . So apparantly that statement was true . I have troubles with a Know-It-All myself . So I just accept some of what he says . God bless, Ken |
| Stick welding
01-27-2013 19:01:43
96.53.210.246
Re: Oxygen Bottle Replacement in reply to Ken-Pa, 01-27-2013 18:50:00
| I was intending to yell at you Ken, just in general so one else follows this practice because the first thing you learn in O/A safety is to never open the acetylene very far in case you have to shut it off in a hurry. If your cylinder uses a key always leave it in place for this purpose. Yelling at your supplier for giving you this wrong info about acetylene might be in order though. It wasn't just wrong info, it was dangerously wrong. Your welding supply could be called Airco and have nothing to do with the old Airco brand name/trademark. Airco was very big in O/A and formed a division that originated many cutting machines, including the Radiagraph, Camograph and pipe cutting machines. They also held the first patents and introduced MIG welding in 1948. |
| Ken-Pa
01-27-2013 19:52:31
75.179.10.67
Re: Oxygen Bottle Replacement in reply to Stick welding, 01-27-2013 19:01:43
| I will definitely mention it to the guy at Airco next time out . I appreciate the info . I'm definitely not what you'd call a welder but do enjoy the challenge & experience learned . I'm only a hobbiest doing my own repairs . I definitely don't profess being a know it all . I'm enjoying plus wanting to learn & I do learn new things daily . God bless , Ken |
| Stick welding
01-27-2013 21:44:04
96.53.210.246
Re: Oxygen Bottle Replacement in reply to Ken-Pa, 01-27-2013 19:52:31
| Look in a manual that comes with a torch set. I'm almost certain it will state not to open the acetylene more than 1 1/2 turns. If it doesn't, you can refer to the oxy/acetylene handbook put out by Esab. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
