Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Oxygen Bottle Replacement
Stick welding
01-27-2013 16:34:42
Why? If you run out, you run out. Oxygen not a big deal but with some cylinders, especially shielding gas, you don't want to run out in the middle of a weld. Usually on shielding gas cylinders you replace them when the pressure is below 100 PSI. There are some cylinders that say on them to leave at least 25 PSI in. I think it's so they don't get contaminated but the proper procedure for filling cylinders, especially argon, is to purge the cylinder before filling it so you are guaranteed 100% pure argon. It is very noticeable when welding aluminum if you have dirty argon. Sometimes the guy filling it is in a hurry or too lazy to purge the cylinders. Cylinders are also routinely switched from one type of gas to another.
01-27-2013 16:57:57
 Re: Oxygen Bottle Replacement in reply to Stick welding, 01-27-2013 16:34:42
If you inhale a big lungfull of Argon does it make you talk like Donald Duck?
01-28-2013 06:07:42
 Re: Oxygen Bottle Replacement in reply to GeneMO, 01-27-2013 16:57:57
No, you will sound like Darth Vader, and then you will suffocate.
You actually have to "dump" the gas from your lungs by getting your lungs higher than your mouth.
01-27-2013 18:46:22
That's helium!
02-04-2013 16:22:45
 Re: Oxygen Bottle Replacement in reply to rabbit, 01-27-2013 18:46:22
Yes, I knew that. I was trying to be "funny"
A bad habit of mine.
