Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Oxygen Bottle Replacement
Ted in NE-OH
01-27-2013 16:01:10
Always return bottle with at least 15 psi.
Stick welding
01-27-2013 16:34:42
 Re: Oxygen Bottle Replacement in reply to Ted in NE-OH, 01-27-2013 16:01:10
Why? If you run out, you run out. Oxygen not a big deal but with some cylinders, especially shielding gas, you don't want to run out in the middle of a weld. Usually on shielding gas cylinders you replace them when the pressure is below 100 PSI. There are some cylinders that say on them to leave at least 25 PSI in. I think it's so they don't get contaminated but the proper procedure for filling cylinders, especially argon, is to purge the cylinder before filling it so you are guaranteed 100% pure argon. It is very noticeable when welding aluminum if you have dirty argon. Sometimes the guy filling it is in a hurry or too lazy to purge the cylinders. Cylinders are also routinely switched from one type of gas to another.
GeneMO
01-27-2013 16:57:57
 Re: Oxygen Bottle Replacement in reply to Stick welding, 01-27-2013 16:34:42
If you inhale a big lungfull of Argon does it make you talk like Donald Duck?
Gene
mkirsch
01-28-2013 06:07:42
 Re: Oxygen Bottle Replacement in reply to GeneMO, 01-27-2013 16:57:57
No, you will sound like Darth Vader, and then you will suffocate.
You actually have to "dump" the gas from your lungs by getting your lungs higher than your mouth.
rabbit
01-27-2013 18:46:22
That's helium!
GeneMO
02-04-2013 16:22:45
 Re: Oxygen Bottle Replacement in reply to rabbit, 01-27-2013 18:46:22
Yes, I knew that. I was trying to be "funny"
A bad habit of mine.
Gene
