TractorLinks.com
Tool Talk Discussion Forum
Re: Schumaker Battery chargers got around to looking
old
01-25-2013 17:39:52
Geo, yes I do understand a good bit about electronics I have forgotten a good bit more then many people ever did learn about electronics. But then I was a Navy E.T. and did computer repair many years ago. I learned to hate electronics over the year. Still remember an odd thing happening when I was playing with a short wave radio and heard a broadcast of JFK getting shoot but what makes it odd is that it was years after the fact but it seemed to be one from the day it happened.
George Marsh
01-26-2013 04:29:38
 Re: Schumaker Battery chargers got around to looking in reply to old, 01-25-2013 17:39:52
Old,
Chargers aren't that difficult to fix. You shouldn't have that much difficulty. Don't use the boost to start a car and you should be good. If you live close, I would fix it for you.
George
old
01-26-2013 08:55:43
 Re: Schumaker Battery chargers got around to looking in reply to George Marsh, 01-26-2013 04:29:38
Do not know about that boost thing since I use it from time to time and never had any problems with doing so. I have 3 of these chargers. As for you living close I am in Missouri the Lake of the Ozarks where are you??
George Marsh
01-26-2013 15:18:58
 Re: Schumaker Battery chargers got around to looking in reply to old, 01-26-2013 08:55:43
Too far, Terre Haute, In
old
01-26-2013 15:39:13
 Re: Schumaker Battery chargers got around to looking in reply to George Marsh, 01-26-2013 15:18:58
I know where that is at. Had a break down back in July of 1980 when the IH pick up I was towing behind my 68 Dodge charger lost a rear wheel. I did go out and look at a couple dodge alternators I have but the diodes in them look way different so those do not look like they would work. Also stopped at O'Reilly's and looked in the book for diodes and all that I found that might be close where special order things
George Marsh
01-27-2013 06:08:07
 Re: Schumaker Battery chargers got around to looking in reply to old, 01-26-2013 15:39:13
Old,
Can you post a pic of the inside of your charger? I'll check what I have in my box of used diodes. I think the last time I replaced diodes in the manual charger I purchased 44 years ago, I used two diodes in a square metal package. Just have to get the right combo. Have to scratch my head and figure out if connect the two out wires from the transformer to cathodes or anodes.
George
old
01-27-2013 09:40:30
 Re: Schumaker Battery chargers got around to looking in reply to George Marsh, 01-27-2013 06:08:07
The diode that cam out is a EDAL F7C3 9417 The solder on part is the wide end of the V and the bolt on heat sink part is the + end. Hope that explains it correctly and in a way you understand. Been to many years since I did much in Electronics to remember which end is which as in the correct terms. By the way it is about as big around as a persons index finger. Below the big part is an area for a wrench and a 17MM wrench is just small enough not to fit
JMOR
01-27-2013 20:20:28
 Re: Schumaker Battery chargers got around to looking in reply to old, 01-27-2013 09:40:30
Quoting Removed, click Modern View to seeDid you look at the link that I posted????????!!!
old
01-27-2013 20:43:13
 Re: Schumaker Battery chargers got around to looking in reply to JMOR, 01-27-2013 20:20:28
Yes and I think I also book marked it but right now $12 for each is a bit to much for me LOL
