Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Propane furnace in COLD weather
Stephen Newell
01-22-2013 05:08:13
What I've always understood about propane is that it is a liquid and it comes to a boiling point at normal air temperature and the vapors of it flow to a persons house. When the temperature outside gets very low the liquid looses the means of coming to a boiling point so it doesn't produce vapors as well so you don't get vaporized gas at the house as well. The only real solution is to raise the temperature of the tank or insulate it from getting so cold.
01-22-2013 05:53:53
 Re: Propane furnace in COLD weather in reply to Stephen Newell, 01-22-2013 05:08:13
Insulate the tank so it doesn't get so cold ? The problem could be that the tank is already too cold . the tank and liquid LP needs to absorb heat to vaporize and maintain usable pressure. Odds are the problem is not the tank but maybe a regulator and likely the rarely used furnace. Time to get off the wallet and call a LP expert repair person before blowing the house up.
