My problem is that it is COLD outside! Northern Minnesota, the low tonight is -21 deg F. My propane furnace does not light very well when it drops below -10 deg F. The first two burners will light briefly, but the flame sensor is on the farthest burner and if it does not light right away it shuts off the gas. I have to use a torch and hold it on the flame sensor to light the furnace.
I have a 500 gallon propane tank, 60% full. The tank is 120 feet from the house, and the line runs uphill to the house. Copper line, 1/2 inch size. I realize that propane vaporizes at -44 deg F.
What are my options to solve this problem? I would rather not have to cover the tank with a quilt or heat it. My propane company suggested moving the tank closer to the house, but I would rather not. Would running a bigger line help? Maybe 3/4" instead? Any ideas appreciated.
