Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Electric power washer
Cliff Nelson
01-20-2013 18:51:27
Depends on how much you want to spend. We had a 1800 psi @ 3.2 GPM electric unit with a Cat pump with a "hot kit" capable of running 175 degree water. I used it a lot for my repair business. Cleaned good and was very satisfied with it. We run 155 degree water through it and never use detergent for oil and grease. Ours also had pressure switches so when you stop the water at the wand it shuts the motor off to prevent heat buildup in the pump. I have a new one ordered that is basically the same thing. The motor finally gave up on the old one.
bob in oakboro
01-20-2013 20:08:15
 Re: Electric power washer in reply to Cliff Nelson, 01-20-2013 18:51:27
Cliff:
What brand was it and what brand/model are you planning on buying?
Cliff Nelson
01-21-2013 05:45:36
 Re: Electric power washer in reply to bob in oakboro, 01-20-2013 20:08:15
The old one was a Swanson. It was a small company that assembled the units with available parts. They are no longer in business. The new one is an Aaladin as they were able to meet our requirements of 155 degree water and automatic shut off. There are a lot of choices for using water below 140 degrees.
