Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: buying/renting scaffolding advice...
Pops1532
01-19-2013 19:15:41
Forget the stack scaffold unless you're doing brick.
Get yourself two250# or 300# rated 8' fiberglass step ladders; two 250# or 300# rated fiberglass or aluminum extension ladders; two aluminum ladder jacks; and an aluminum stage (plank).
Watch C/L for the stage, ladder jacks and extension ladders. Buy new step ladders.
Set up time for ladders and stage is a fraction of what it takes to set up stack scaffold.
Plus you'll use the ladders much more often than you'll use scaffold.
I recommend Werner ladders and stage, and Stinson ladder jacks.
Stages are available in many sizes. They make 12 & 14" wide. I have 12' long (24' cut in half), 20', and 24'. All mine are 12' wide X 6" tall. The 14" wide are 8" tall.
A 16 or 20' stage would be a good length for someone that just needs one.
I also have a bunch of stack scaffold. It rarely gets used. It's good to use if you're laying blocks or bricks, or rolling around on a concrete floor inside a building. Otherwise the ladders and stage are better.
