Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Mig weld cast steel?
Stan in Oly, WA
01-19-2013 18:27:31
Hi dboll,
While that's technically true, you have to be good enough with a cutting torch to be able to tell the difference between cutting and just burning through and blasting the molten metal out of the cut with the jet of high pressure oxygen. Cast iron can be cut with oxy/fuel in much the same way ferrous metal can be cut with a welding rod under desperate circumstances. Many people use a cutting torch so poorly that there wouldn't be much difference in the appearance of cutting through steel and burning through cast iron.
