Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Mig weld cast steel?
george md
01-18-2013 11:38:41
Joel,
If it is cast steel , it will weld with
7018 quite well. But Cat is too cheap to use
cast steel in a bell housing, it's most likely
cast iron and an oven preheat and oxy/acet weld
with cast iron in stick form would be best .
george
JOB
01-18-2013 17:23:40
 Re: Mig weld cast steel? in reply to george md, 01-18-2013 11:38:41
George, what do you use for your cast? Is it the square cast rod or do you use the round 1/8 inch tig rod. I have a small cast job and tried to buy some square cast rod, I was quoted a price of $20.00 a pound and had to buy a full box. The piece I want to weld is not worth that. I have a little Tig rod on hand. That should be use able with Oxygen/Acetylene????
george md
01-18-2013 18:15:51
 Re: Mig weld cast steel? in reply to JOB, 01-18-2013 17:23:40
Job,
Yes ,I use the square rod, I buy it in
50 lb boxes , it's 8.00/lb . last time I
ordered 50 of 3/16 & 50 of 1/4 , ouch. If you
need some send me an email with a phone #
and I'll call you.
george
JOB
01-19-2013 03:19:15
 Re: Mig weld cast steel? in reply to george md, 01-18-2013 18:15:51
I just called one place when I asked about cast rod. He said that only one supplier in the metro area has cast rod. I live in a large metropolitan area, it is hard to believe that only one supplier had cast rod. I will call a few others. After seeing the work you have done on stuff I have had no to little luck with you convinced me that oxygen/acetylene is the way to weld cast.
The piece I have to weld is not a rush, but if I can't find cast rod locally, reasonably I will get a hold of you. Thanks
Copyright © 1997-2015 Yesterday's Tractor Co.
