TractorLinks.com
Tool Talk Discussion Forum
Re: Portable generator problem
Billy Shafer
01-14-2013 13:28:18
Remove the back cover of the generator.Look at the windings. If they are black or a dark brown. They are most likely shorted.What generator do you have.
Generator tech for over forty years.
wilson ind
01-14-2013 14:18:26
 Re: Portable generator problem in reply to Billy Shafer, 01-14-2013 13:28:18
I have an electric start honda 4500 belt drive starter is junk any other starters that would fit???
Billy Shafer
01-14-2013 16:23:53
 Re: Portable generator problem in reply to wilson ind, 01-14-2013 14:18:26
What model Honda.
wilson ind
01-15-2013 06:40:54
 Re: Portable generator problem in reply to Billy Shafer, 01-14-2013 16:23:53
ES 4500
runwolfe
01-14-2013 13:43:44
6600 is a yamaha
5500 is a colman with a yamaha engine
Billy Shafer
01-14-2013 13:54:05
 Re: Portable generator problem in reply to runwolfe, 01-14-2013 13:43:44
Yamaha is a pretty good unit. Unless it is real old. It should not have brushes. Should have a terminal strip. Where the wires for output join up. Check for loose connections.As I said take a look at the rotor and stator windings. If they are dark,most common is a short.May not be worth fixing.
What Model is it. With model and serial number. I can bring up a print and check out sheet.
runwolfe
01-14-2013 17:38:41
 Re: Portable generator problem in reply to Billy Shafer, 01-14-2013 13:54:05
Billy, Thanks! It is brushless. YG6600DE
Serial # 250940 I think. I bought it new in 2004.
Billy Shafer
01-14-2013 19:49:42
 Re: Portable generator problem in reply to runwolfe, 01-14-2013 17:38:41
Thanks give me some time to do some checking. Has it been working ok before. Because there was one that had a wire in the wrong position. Would burn out after some time.
runwolfe
01-15-2013 03:07:54
 Re: Portable generator problem in reply to Billy Shafer, 01-14-2013 19:49:42
has been working fine
