TractorLinks.com
Tool Talk Discussion Forum
was this a bad idea?
kevinecwi
01-11-2013 18:08:58
Using a hydraulic pump coupler for a generator. After less than 20 hours the rubber is starting to separate.
ih_bug
01-13-2013 19:03:09
 Re: was this a bad idea? in reply to kevinecwi, 01-11-2013 18:08:58
I built the same generator and used the same coupler it ate the first spider and I played with the alignment no trouble since . my sawmill uses one to drive the hydraulic pump also runs at 3600rpm was out of alignment from the factory and ate the spiders I had to drill the mounting holes out and realign the pump no trouble since . woodsplitters same thing.
kevinecwi
01-12-2013 19:29:04
Thanks for all the feedback fellas. I'm not going to rule out the alignment issue but I really feal like I got it within tolerance. If I slowly pull the engine over I can not hear any noise (binding) coming from the coupler.
For time being I'm going to try a new spider as they are rather inexspensive and lube it with dielectric grease and see how long it lasts. Thanks again to everyone who replied and posted links.
VernMI
01-13-2013 05:09:17
 Re: was this a bad idea? in reply to kevinecwi, 01-12-2013 19:29:04
LoveJoy also has sintered bronze spiders and nylon spiders that can be used in place of the rubber one in there now.
Stick welding
01-12-2013 18:39:39
The coupling probably isn't rated for the RPM or the HP you have. There are other types of couplers that would work better. Belt drive is no good unless the generator is rated for side load on the shaft. Inline like you have is better.
RusselAZ
01-12-2013 18:00:12
How many RPM is that running? Spiders don't like over 1800. You can make them last longer by putting some silicone dielectric grease on them when they aren't aligned perfect. You will be better served with a coupler that looks like a bellows when assembled. Best would be a belt drive.
wisbaker
01-12-2013 17:58:15
Definitely an alignment problem. Dodge para-flex are more forgiving for alignment. Lovejoys and Woods not so much
Diydave
01-12-2013 16:51:34
Take the Question to lovejoy direct.
Russ from MN
01-12-2013 07:06:13
If it is sized right and properly aligned it should run a long time. We used many of them in the paper mill.
JeffNWOH
01-12-2013 06:02:08
I would have to assume that there is some sort of mount under the back end of that genny that we can't see. If not, I'd say that is your problem.
kevinecwi
01-12-2013 14:49:32
 Re: was this a bad idea? in reply to JeffNWOH, 01-12-2013 06:02:08
Yes, there is one bolt in the back of the generator. It is hard to see in pic but I used a shim under the front mounting holes to get better alignment.
JOB
01-12-2013 01:02:50
Love joy is one of the most forgiving coupling on the market. As others have said you have an alignment issue. You will not only wear out the coupling, you will do damage to the piece being driven. You need to re-engineer how you have both pieces mounted. Normally on a larger piece of equipment the motor is shimmed up, and shifted from side to side to get alignment.
Redturbo
01-11-2013 19:19:34
I looked into "lovejoy" couplers for a project. Max 1 degree is all it will tolerate. Guessing thats your issue.
Rollie NE PA
01-11-2013 18:55:11
Looks like a alignment issue. I believe there are different grades of rubber spiders also.
marloweg
01-11-2013 18:45:40
get your self two chain sprockets and us a double roller chain to couple it that way if it is a little out of line it will not hurt anything. Massey Harris used it on tractor for years and it is cheep
Dalet
01-11-2013 18:37:56
I had that problem with the spider getting wrecked on a Grasshopper mower a few years back. There is an alignment issue. It isn't perfect, there isn't much room for error with them.
Retired Farmer
01-11-2013 18:16:32
It better not, I put one of those on my bobcat pump and I don't plan on replacing it in twenty hours if I ever get it running again.
