| Tool Talk Discussion Forum |
Topic: hdy clinder ?
[Return to Forum]
| Author |
[Modern View]
| Jo Bird
01-10-2013 07:20:45
173.87.150.249
Has any one ever made a two way cylinder from a one way cylinder such as you find on a boss snow plow ? I bought a manual 6 ft eagle V plow for a UTV and am going to make it a scoop instead of the V. I know I could just add some springs to pull it back , but would prefer hdy if possible..I will be mounting it on a small 4 wheel drive tractor. Its time to give the old Economy tractor a rest and me to.. LOL. Thanks in advance for any advice.. Jo |
| Jo Bird
01-10-2013 14:02:47
173.87.150.249
Re: hdy clinder ? in reply to Jo Bird, 01-10-2013 07:20:45
| Gentlemen thanks for the replies. I never thought about rod and bore size being the same or the seals only holding pressure in one way. Guess I'll be looking for some springs to retract the blade to its straight position . Thanks again.. Jo |
| mkirsch
01-10-2013 13:50:01
64.80.110.75
| You can't just drill and tap into the cylinder tube above the piston. There isn't enough material there to hold up under pressure. You've got maybe two threads there. Besides, the fitting would protrude down into the cylinder and tear up the piston.
To even have a chance at making it work, you would have to weld an outlet port to the tube. Probably a good job for a TIG welder. |
| Rickieblue
01-10-2013 13:43:57
173.87.150.149
| Look at the link I posted for reasonably priced double acting cylinders |
| JOHNNYfromMI
01-10-2013 12:50:28
74.115.62.95
| On some single action cylinders the ram is the same size as the bore. So there is no way of putting high pressure oil on the other side of the cylinder. |
| Jo Bird
01-10-2013 10:52:24
173.87.150.249
| old Thanks for the reply.. but I'm trying to go the other way, making a single acting into a 2 way. I wondered if any one has tapped the side or rod end with success..to retract the rod ? I don't find any small, small 2 way cylinders and they are quite pricey at that. This is a low budget project if you know what I mean.. Jo |
| old
01-10-2013 11:01:03
209.86.226.59
Re: hdy clinder ? in reply to Jo Bird, 01-10-2013 10:52:24
| Making a single acting into a double is not possible due to the fact the hyd seals in the single acting is set up for pressure only one way and if you did some how drill and tap and installed a fitting it would not last very long if it lasted one time. Double acting cylinders are easy to find and on my place a dime a dozen but I have a lot of them laying around |
| old
01-10-2013 09:08:47
209.86.226.19
| Very easy to set a 2 way hyd cylinder up so it is a one way acting cylinder. You do need to make or buy a vent plug for the port you do not use or it will vacuum lock on you which can cause damage to the cylinder seals. Most any good farm and home place will have the vent or you can make a vent plug by drilling a small hole in a pipe plug such that it does not let a lot of crude into it |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
