| Tool Talk Discussion Forum |
Topic: Hydraulic seal tool
[Return to Forum]
| Author |
[Modern View]
| jack345
01-07-2013 08:39:54
72.160.52.130
I'm working on a hydraulic cylinder and the shaft seal (40mm ID x 60mm OD) looks like white nylon plastic book calls it KAYABA. Its rather stiff and hard to move, is there a tool for removing and installing this type of seal? The hole it fits into is 50mm and then goes to 60mm for seal seat.Shaft is 40mm.Seal is about 1/2" wide. |
| greygoat
01-08-2013 08:50:12
184.158.55.125
Re: Hydraulic seal tool in reply to jack345, 01-07-2013 08:39:54
| I've had the set, like in "DH from Carolina's" Photo for 30 years..works great..got them from Martin Fluid Power. (google: Martin Fluid Power) |
| greygoat
01-08-2013 08:49:35
184.158.55.125
| I've had the set, like in "DH from Carolina's" Photo for 30 years..works great..got them from Martin Fluid Power. (google: Martin Fluid Power0 |
| NCWayne
01-07-2013 21:42:21
69.40.232.132
| | Sounds to me like your talking more about the rod wiper than an actual rod seal. Most rod seals are of a relatively high durometer but not as stiff as an actual plastic like your describing. The wipers, on the other hand, are typically made of alot tougher material than the actual seals, and that, coupled with the shape is not condusive with the use of the tool DH suggests. That said I don't know of anyone making a tool to help insert a seal/wiper/etc made out of that hard of a material. Now if it's actually a U seal of some description then the instillation tool DH recommends can't be beat. I spend alot of years putting seals in with no tool, and when those came out I would have given a mint for one as they make putting a seal into it's hole alot easier, especially when it's a small diameter seal going down into a hole your fingers won't fit in. With all of that said, the harder seals will typcally benefit from being soaked in HOT water to soften them up a bit before putting them in. Too, there are small diameter buffer seals (don't figure that's what you have as they typically have an oring energizer in the groove behind them)that need to be prestretched before installing it in the bore. Failure to do so on those will typically end with the seal being messed up when the rod is insterted through it. Hope this helps and good luck. |
| DH in Carolina
01-07-2013 15:12:25
173.212.6.174
|  Here"s the type of seal installer I had to use to collapse the seal to install in a 1 inch bore. There are three differant sizes and work wery well. I ruined one seal trying to install without this tool. |
| Stick welding
01-07-2013 10:17:26
198.53.25.107
| Kayaba is most likely the manufacturer and if there's a special tool, they will have it. Kayaba makes hyd. jacks but is most known for making motorcycle suspension. |
| Dalex
01-07-2013 09:59:40
108.38.146.180
| I remember heating the nylon seals in boiling water to increase their flexibility ...collapse the seal into it's self with round nose pliers and then release it into the groove, that should do it .... |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
