TractorLinks.com
Tool Talk Discussion Forum
Re: Compressor electrical question
DH in Carolina
01-05-2013 15:41:45
Here's the simple way to wire the contactor. you can't use the overload block because it is for three phase and you only have single phase power. Solid state overload must see current on all three legs or it will trip out. This will work if you have internal motor overload protection. If you don't have motor protection get a single phase conbination starter with overload protection. If you ever worked on industrial equipment you will find most motors don't have internal overload protection.
Stephen Newell
01-05-2013 16:41:28
 Re: Compressor electrical question in reply to DH in Carolina, 01-05-2013 15:41:45
Thankyou for the sketch. I now finally have given up on the overload protection and have taken it off for good. Overload protection is shown in the owners manual and also in different sketches I found online. Not having a complete understanding of this magnetic switch I kept fealing like if it was there it was suppose to be there. The motor that I have on the compressor has its own overload protection.
George Marsh
01-05-2013 15:50:55
DH, This will work providing the contacts for L1 and L3 are good and there is a path through the current sensor. I think, in a previous post Stephen said L1 was bad. Some code people may want you to use both poles on the pressure switch. I don't see an issue with your diagram.
George
Stephen Newell
01-05-2013 16:03:52
 Re: Compressor electrical question in reply to George Marsh, 01-05-2013 15:50:55
There seems to be something going on with L1. I finally got it to work but its a lot harder to work than the other two manually. Anyway I get the picture and can use what ever two contacts that do work.
George Marsh
01-05-2013 16:39:04
 Re: Compressor electrical question in reply to Stephen Newell, 01-05-2013 16:03:52
Stephen, There may be an issue with the current sensor too. If there is, there are 3 screws, #2,#4,#6 (T1, T2, T3). If you loosen them, you may be able to remove the bottom half, current sensors.
I'm sure the code people will sound off and tell you not remove it. My reply is there hasn't been any current sensors when you were using the pressure switch and you didn't get killed or burn up the motor. There aren't any current sensors on other air compressors either. There are only factory internal motor protectors.
Let us know if it works. There is no reason why it shouldn't, except for a bad contactor.
George
Stephen Newell
01-05-2013 16:59:39
 Re: Compressor electrical question in reply to George Marsh, 01-05-2013 16:39:04
I thought the current sensor was part of the lower unit with the overload protection. There is some device that you adjust the amperage you want.
George Marsh
01-05-2013 19:04:20
 Re: Compressor electrical question in reply to Stephen Newell, 01-05-2013 16:59:39
Stephen, you are right, the bottom half is the current sensor. It was designed for 3 phase, current running through L1, L2 and L3. DH thinks it may not work on single phase. He gave you the simple way to install it. I can show you how you can try to use the current sensor, but only after the experts show you how to wire it.
Wire it the way DH showed and see if that part of your contactor works. It will be simple to add in the sensor circuit.
Keep in mind there was no current sensor when you had the pressure switch installed. Never seen a small air compressor wired with a current sensor, so what's the big deal if you leave it out? Your 3 phase contactor was an after market add on.
George
Stephen Newell
01-05-2013 20:54:53
 Re: Compressor electrical question in reply to George Marsh, 01-05-2013 19:04:20
All of this is more than getting the compressor running. I want to understand it and learn from it too. I can forsee having to contend with another magnetic starter in the future. I appreciate everything everybody has done for me especially you running the gauntlet with something more controversial. It wasn't what I was needing at the time but if I had the parts I might have broken one leg temporarily to use the compressor in an emergency. I had to order a replacement pressure switch so I'm not going to be doing any permanent wiring until the end of the comming week.
One thing I will never understand is why they don't just make a heavier duty pressure switch.
