TractorLinks.com
Tool Talk Discussion Forum
Re: Compressor electrical question
Determined
01-05-2013 08:10:18
You have plenty of electrical advise on here already so I won't go further.
Have you checked the check valve between the compressor head and the storage tank?
If it is leaking it will preload the compressor pump and no matter how large your contactor is you will be overloading the motor on start-up eventually destroying it, if I recall you said you had to replace the motor once already.
Dave
Stephen Newell
01-05-2013 08:36:16
 Re: Compressor electrical question in reply to Determined, 01-05-2013 08:10:18
It's more probable cold weather is the culprit as the compressor starts harder near freezing.
Determined
01-05-2013 11:01:51
 Re: Compressor electrical question in reply to Stephen Newell, 01-05-2013 08:36:16
Consider trying one of those magnetic block heaters on the base of compressor head with one of those thermostatically controlled block heater extention cords powering it.
Dave
