Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Compressor electrical question
George Marsh
01-05-2013 03:48:14
Here is the deal, what I tell you the NEC cops will tell you is wrong, you are going to blow up the world, kill someone, kill yourself, get a ticket for breaking the law and so on.
Then the advice I'm going to give you is worth what you are paying for it......
Secondly, the contactor you have is not the one that came with the air compressor. It is something so one got off a 3 phase device.
That said, the bottom half of your motor contactor is not set up for your motor and I would remove it using only the top contactor. Again, NEC cops will jump all over me for saying this.
I would get an extension cord and wire it to your pressure switch. Black wire on one side and white wire on the other side of the pressure switch. Use the ground wire if your 220v wire is not already grounded to the compressor. Then send the black wire from the other side of the pressure switch to A1 and the white wire to the other side of the coil. Plug in extension cord and see if contactor pulls in. If it does, you are half way home.
Wire the 220v to L2 & L3 and the motor to the terminals below T2 & T3.
Forget the overload protection on the contactor. I've never seen a motor that didn't already have it's own overload protection. Make sure your circuit breakers are the right size for your wire. Put the contactor in a metal electrical box. You should be good to go.
Hope I've been a help. Let me know if it works.
Stephen Newell
01-05-2013 05:03:32
 Re: Compressor electrical question in reply to George Marsh, 01-05-2013 03:48:14
It may perhaps be the wrong magnetic starter for my compressor but I bought the compressor new directly from Ingersol Rand and that was the switch that came with it. The motor however went out a few years back and was replaced. You are right the new motor has its own overload protection where I don't think the original motor did. I did give out some bad info about the coil being 110v. I have since learned it is 220V. I also do need to be careful not to energize the compressor itself. The compressor is used outdoors where the ground often gets wet around it. All in all with everybodies help, I'm getting closer to understanding this unit. Thankyou.
