Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Compressor electrical question
01-04-2013 11:56:52
Neither. Line power from a local shut off switch or wall receptacle to the line side of the magnetic starter. Load side of be starter to the motor. Control power from the line side of the starter to the pressure switch and back to the coil, through the overload contacts. Coil voltage must match line voltage . Don't be one of those d!cks that use the 240V supply to the coil and wire to ground to obtain power for a 120V coil. Time to hire a pro before you burn the place down, cripple or kill somebody. You hire a pro to do your dental work .
Ken Macfarlane
01-04-2013 13:48:12
 Re: Compressor electrical question in reply to buickanddeere, 01-04-2013 11:56:52
Those little step down transformers for 240-120 are common and handy as a lot of stuff uses 120 V control voltage. Like he said, ground wires are not there for you to wire into a circuit.
