TractorLinks.com
Tool Talk Discussion Forum
Re: Half of 60 Amp fuse panel is dead
d beatty
01-04-2013 11:54:09
I would not pull the meter. Our electric company only allows their men or an authorized electrician to remove meter. If you get an electrican you should have him put in a main through out switch on the panel.
Nisse
01-04-2013 14:32:10
 Re: Half of 60 Amp fuse panel is dead in reply to d beatty, 01-04-2013 11:54:09
Don't think I will pull the meter myself, talked to the co-op and they will do it, just have to schedule it a couple days ahead. Was more wondering about pulling the breaker, I have replace several before but never when the panel is live. Going to take a closer look at it tomorrow, supposed to be warm(about 25 degrees).
Thanks,
John
d beatty
01-04-2013 14:38:53
 Re: Half of 60 Amp fuse panel is dead in reply to Nisse, 01-04-2013 14:32:10
John like I said before if it can be done put a disconnect switch between the meter and box so if you have to do this again you won't have to call someone out.
nisse
01-08-2013 20:01:38
 Re: Half of 60 Amp fuse panel is dead in reply to d beatty, 01-04-2013 14:38:53
I got the problem fixed this weekend, turned out to be real easy. I never actually looked at the one panel until Saturday, just took my dad"s and brother"s word there was no way to kill power, it turns out that there is a 100 amp main breaker. I just replaced the bad 60 amp breaker and everything is fine. Thanks for all the help.
John
merlynr
01-09-2013 07:33:27
 Re: Half of 60 Amp fuse panel is dead in reply to nisse, 01-08-2013 20:01:38
Glad you got it fixed and so easily. Makes you feel good when it's something simple and you're in the middle of a project.
