TractorLinks.com
Tool Talk Discussion Forum
Re: De Walt hammer drill brush question
old
01-03-2013 15:29:05
I do plan to take it all apart and then use emery cloth to clean up the armature and also check it for shorts. But this with the brushes was just a fist check type of thing since it does arc and spark a lot at the brushes
GUIDO
01-03-2013 18:56:06
 Re: De Walt hammer drill brush question in reply to old, 01-03-2013 15:29:05
Hello old,
The brushes skipping on the commutator will create a lot of sparks and draw a lot of current.
Taking the edge off the brushes as per my drawing will also decrease the current the motor will draw. Spring pressure on both brushes should be about the same. If you don't have a way to check the tension, you should try to put in a new set if possible.
Guido.
old
01-03-2013 20:39:29
 Re: De Walt hammer drill brush question in reply to GUIDO, 01-03-2013 18:56:06
The brushes both look good and the springs seem to be good also. I have not done much repair in this type of thing for years but did a whole lot if it back when I worked at tracker marine so not new to this just been a few years as in well I left there in 1992 so yep a few to many maybe
GUIDO
01-04-2013 06:32:56
 Re: De Walt hammer drill brush question in reply to old, 01-03-2013 20:39:29
Hello old,
If the springs and brushes look good, then just a good cleaning may be that its all you need to do. Taking the edges off the brushes will do two things: decrease the amp draw, and increase the tool's R.P.M's. Lighter springs will do the same thing.
Guido.
Dusty MI
01-03-2013 17:51:08
Do NOT use emery cloth emery is a conductor, it can leave dust behind and cause a short, then let the smoke out. Use sand paper, it's a non-conductor.
Dusty
old
01-03-2013 18:19:08
 Re: De Walt hammer drill brush question in reply to Dusty MI, 01-03-2013 17:51:08
Been using emery cloth for this for years. I do clean things back off with a electric spray after and would no matter what I used be it emery or sand paper since both can/will leave residue behind and sand is as bad as any thing emery cloth would leave
