Machining Grade 8 Bolt
I needed some pointed set screws. The store did not have them. I have a 6" Jet lathe and am considering making them from grade 8 cap screws. I have limited experience with carbide tools but get along pretty well shapening HS tool bits. Is grade 8 too hard to turn?
Grade 8 bolts are fairly soft, about 20 - 25 RC hardness and can be turned very eazly with HSS tool bits, grind your tool bit with about a 7 degree relief angle and a 3 - 5 degree positive rake angle on the top of tool,and run about 300 - 500 RPM, with a small cut on your Jet lathe.
If you are ever in doubt about being able to cut something with HSS, try filing it first. If you can cut it with a file, you can cut it with HSS.
I have a hand-held bandsaw. A friend was using it to cut bolts, brought it to me because it stopped cutting. I don't know how many he cut but I looked at the heads and they were grade 8s. There were no teeth left on the good bi-metal blade.
HSS will cut alot more stuff than most people give it credit. You just have to take it slow. Most people get in a hurry and that is what smokes their tooling
