| Tool Talk Discussion Forum |
Topic: De Walt hammer drill brush question
[Return to Forum]
| Author |
[Modern View]
| old
01-02-2013 17:39:01
209.86.226.57
Ok so I got this DeWalt hammer drill the other day. Checked out the brushes in it One side of each brush showed a lot of wear but the other side was fine. So I was just going to rotate them 180 in the holders so as to let then wear even again but the wire is not long enough to do so. But I can pull the plug loose in the armature and switch them side to side so will that make it run back wards of what id does now. By the way this is a forward reverse type drill so will not really matter other then having the switch set wrong to go right it it does make it run back wards Thanks |
[Reply] [No Email] | |
| GUIDO
01-03-2013 12:59:55
71.168.249.98
Re: De Walt hammer drill brush question in reply to old, 01-02-2013 17:39:01
|  Hello old, What you need to do is take a knife or razor blade, and take the edge off the leading and the trailing end of the brush. A round file will smooth out the contact area of the brushes. The edges get very sharp and that makes them bounce rother then fallow the comm. Make sure you clean the segments as well Good luck.............................Guido. |
| old
01-03-2013 15:29:05
209.86.226.34
Re: De Walt hammer drill brush question in reply to GUIDO, 01-03-2013 12:59:55
| I do plan to take it all apart and then use emery cloth to clean up the armature and also check it for shorts. But this with the brushes was just a fist check type of thing since it does arc and spark a lot at the brushes |
| GUIDO
01-03-2013 18:56:06
71.168.249.98
Re: De Walt hammer drill brush question in reply to old, 01-03-2013 15:29:05
| Hello old, The brushes skipping on the commutator will create a lot of sparks and draw a lot of current. Taking the edge off the brushes as per my drawing will also decrease the current the motor will draw. Spring pressure on both brushes should be about the same. If you don't have a way to check the tension, you should try to put in a new set if possible. Guido. |
| old
01-03-2013 20:39:29
209.86.226.57
Re: De Walt hammer drill brush question in reply to GUIDO, 01-03-2013 18:56:06
| The brushes both look good and the springs seem to be good also. I have not done much repair in this type of thing for years but did a whole lot if it back when I worked at tracker marine so not new to this just been a few years as in well I left there in 1992 so yep a few to many maybe |
| GUIDO
01-04-2013 06:32:56
71.168.249.98
Re: De Walt hammer drill brush question in reply to old, 01-03-2013 20:39:29
| | Hello old, If the springs and brushes look good, then just a good cleaning may be that its all you need to do. Taking the edges off the brushes will do two things: decrease the amp draw, and increase the tool's R.P.M's. Lighter springs will do the same thing. Guido. |
| Dusty MI
01-03-2013 17:51:08
76.250.62.134
| Do NOT use emery cloth emery is a conductor, it can leave dust behind and cause a short, then let the smoke out. Use sand paper, it's a non-conductor.
Dusty |
| old
01-03-2013 18:19:08
209.86.226.40
Re: De Walt hammer drill brush question in reply to Dusty MI, 01-03-2013 17:51:08
| Been using emery cloth for this for years. I do clean things back off with a electric spray after and would no matter what I used be it emery or sand paper since both can/will leave residue behind and sand is as bad as any thing emery cloth would leave |
| Justin SE IOWA
01-02-2013 18:17:16
166.182.80.49
| Only one way to find out...Try it! LOL |
| old
01-02-2013 19:15:59
209.86.226.19
Re: De Walt hammer drill brush question in reply to Justin SE IOWA, 01-02-2013 18:17:16
| I already did it but did not look to see if it had change directions on me or not so figured I would ask and see what others think it might do then I'll look at it and see who might be right LOL |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
