Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: What Kind Of Heater To Dry House Garage Floor
[Return to Forum]
KCTractors
12-29-2012 13:07:10
166.182.80.204
I'm looking to buy a heater to dry the house garage floor from the snow carried in.I was thinking of using a 20" fan while running a torpedo kerosene heater, or should I use radiant type of kerosene heater or would I be better off with a Lp heater of choice. It would be just used while drying off the floor.
[Reply]   [No Email]
Determined
12-31-2012 07:42:01
216.130.212.56
Re: What Kind Of Heater To Dry House Garage Floor in reply to KCTractors, 12-29-2012 13:07:10
I heat my shop with a woodstove.
I have a fan mounted inside of a 8 foot length of stovepipe.
This is mounted to the wall with the top six inches from the celing, the bottom ends 2 feet from the floor with a piece of cardboard attached to it on an angle to fan out the air.
The air is pulled down from the celing and provides constant circulation.
Without the fan it takes 3-4 days for the floor to dry after I bring in a vehicle, with the fan it is dry overnight.
Dave
  [Reply]  [No Email]
ss55
12-31-2012 06:40:40
173.31.19.80
Try using a fan alone before adding heat. Air dew points are low in cold weather. As others said use a broom, scoop or squeege to remove the excess snow and water to reduce the amount of water to dry up.
When the dew point is higher than the temperature of the concrete floor the floor will be damp.
  [Reply]  [No Email]
hillbillyjack
12-31-2012 16:55:02
69.168.144.141
Re: What Kind Of Heater To Dry House Garage Floor in reply to ss55, 12-31-2012 06:40:40
This right here, sweep it out, set an oscillating fan on the floor set on high at one end or in the middle of one side of the garage, floor will dry off without heat.
  [Reply]  [No Email]
JD Seller
12-30-2012 07:15:58
208.126.196.144
The best heat for what your wanting is radiant heat in the floor itself. Which would not be practical to install on an existing floor.
Just about any other heat will work but will be slower in evaporating the water off the floor.
20/20 hide site but your garage should have had floor drains installed under each car bay.
  [Reply]  [No Email]
willie in mn
12-30-2012 02:47:45
67.142.168.25
Moisture in air will condense on cold floor. Heated air by itself won't dry it out with ventilation. Remove snow/water with shovel, broom, or squeege
I can think of 3 methods that will dry it out, two expensive, other free.
Expensive-Radiant floor heat, either electric grid or hot water piping.
Dehumidifier.
Free- sunshine. If you are lucky enuff to have a south or west facing door, open it & let nature do its thing. Open door will also ventilate the humid air out & let drier air in. An open door on opposite side & a gentle wind help a lot.
  [Reply]  [No Email]
Dusty MI
12-30-2012 05:16:15
76.250.62.134
Re: What Kind Of Heater To Dry House Garage Floor in reply to willie in mn, 12-30-2012 02:47:45
Also ceiling hung gas or electric radiant.
Dusty
  [Reply]  [No Email]
Charles (in GA)
12-29-2012 18:36:50
24.181.64.236
As noted, your best options are a bucket and mop and a squeegee. Unless you just want the garage warm, don't waste your time or money on the heater.
Charles
  [Reply]  [No Email]
Russ from MN
12-29-2012 18:09:20
97.25.254.54
An unvented gas heater will put 3 quarts of water in the air for every gallon of propane burned, I would expect nat. gas to do about the same. A vented heater or an electric one would work, but you should squeegee as much out as you can. I use a vented nat gas heater and a fan, but I sweep it out as well as I can first. Every time it snows it's a problem!
  [Reply]  [No Email]
rusted nuts
12-29-2012 17:25:55
75.88.142.252
Bucket and mop.
  [Reply]  [No Email]
GordoSD
12-29-2012 16:50:53
216.106.244.233
Menards, Lowes, HD carry floor squeeges about 30 inches wide and tough, for that purpose.
  [Reply]  [No Email]
GlenIdaho
12-29-2012 16:42:53
71.220.163.185
I use a wet/dry shop vaccum to collect the water. Takes a few minutes to do, but its less expensive that running a heater. Within a few hours the floor is dry.
  [Reply]  [No Email]
David G
12-29-2012 16:24:05
205.215.206.18
Pretty hard to dry the floor with a heater, the floor will be the coldest. I would sweep the water out.
  [Reply]  [No Email]
MSD
12-29-2012 15:36:21
67.4.60.56
LP or torpedo types will create more moisture.
  [Reply]  [No Email]
C.R.
12-29-2012 13:18:54
72.251.63.184
maybe a squeegee? push the snow or water back outside then you dont have to melt and evaporate it,and still have all of that moisture laden air in the building
  [Reply]  [No Email]
504
12-29-2012 19:23:33
199.127.54.155
Re: What Kind Of Heater To Dry House Garage Floor in reply to C.R., 12-29-2012 13:18:54
The best fan I have found is a squirrel cage fan. I bought a small one at HD for the camper,it moves a lot of air(Stanley) and is small in size. I also have two big one salvaged from scrap furnaces.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
