Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Shop floor drain goes dry
12-27-2012 19:03:48
pour some vegetable or olive oil down the drain after filling the trap with water, it will create an oil slick on the water and should slow down the drying out process, they also make a device called a trap primer, it is usually installed on new construction to floor drains that wont be used very often it hooks up to a common used fixture such as a bathroom or laundry tub everytime you turn the facuet on a little bit of water will flow thru the pipe you would need to install below your floor to connect to your floor drain. i would try the oil first, easy and wont cost you much, good luck!
