| Tool Talk Discussion Forum |
Topic: Shop floor drain goes dry
[Return to Forum]
| Author |
[Modern View]
| DKase
12-27-2012 18:43:56
75.102.180.184
Water in the trap in the bathroom floor drain goes dry every 3 days, and the sewer gas fills the shop. I tried RV antifreeze and that lasts a week. I do not have floor heat. I would think floor heat would make the problem much worse. Has anyone come up with a solution for the problem other than causing a plumbing leak to keep the trap filled? |
| LenND
12-28-2012 13:59:38
74.207.160.118
Re: Shop floor drain goes dry in reply to DKase, 12-27-2012 18:43:56
| I agree with Pete. You either have a plugged vent or no vent at all. The vent could also be in the wrong location. The drain is being used as the vent for some reason. |
| jackinok
12-28-2012 08:00:52
162.58.82.136
| go down to a plumbing supply place and buy a screw type rubber plug if you dont use the drain much. then when you need it simply pull the plug. |
| Gregorius
12-28-2012 07:47:13
69.21.250.215
Re: Shop floor drain goes dry in reply to KF, 12-27-2012 18:43:56
| Quoting Removed, click Modern View to see
I have to agree with pete black, I'll bet you have a plugged vent stack. |
| Ted in NE-OH
12-27-2012 19:30:37
72.16.19.80
| That is WAY too fast, you have another problem other than evaporation. |
| pete black
12-27-2012 19:19:06
166.205.68.40
| could be you have a venting problem and the water is being pulled out of the trap whenever a large volume of water is dumped down the drain. |
| downsouth
12-27-2012 19:12:43
205.188.116.142
| Send big Bubba in there every few days to do his thing. Certainly he will stop up the toilet and it will overflow keeping your floor drain adequately filled. Seriously though, if it's really drying out that fast I would be concerned the trap is broken and the water is seeping into the ground under the floor. |
| jper
12-27-2012 19:03:48
108.39.174.161
| pour some vegetable or olive oil down the drain after filling the trap with water, it will create an oil slick on the water and should slow down the drying out process, they also make a device called a trap primer, it is usually installed on new construction to floor drains that wont be used very often it hooks up to a common used fixture such as a bathroom or laundry tub everytime you turn the facuet on a little bit of water will flow thru the pipe you would need to install below your floor to connect to your floor drain. i would try the oil first, easy and wont cost you much, good luck! |
| Retired Farmer
12-27-2012 18:57:07
207.200.116.12
| Why do you have a drain in the floor in the first place? |
| Wade1984
12-27-2012 19:05:07
24.162.137.85
Re: Shop floor drain goes dry in reply to Retired Farmer, 12-27-2012 18:57:07
| Use some vegetable oil to form a layer on top to keep evaporation down. |
| 504
12-27-2012 20:44:17
199.127.54.155
Re: Shop floor drain goes dry in reply to Wade1984, 12-27-2012 19:05:07
| I know it is too late now, but my floor drains all drain out to the downspout tiles on the house. I have no sewer connections to my floor drains. |
| PJH
12-27-2012 21:31:51
50.40.225.246
Re: Shop floor drain goes dry in reply to 504, 12-27-2012 20:44:17
| | You know - I've heard of running the floor drains to the downspout drains, but I always wondered about getting an obstruction downstream and then having it all back up during a hard rain. A roof handles a lot of water. Am I missing something obvious? How would you keep that roof water from backing into your building? As to the original poster - there's got to be a leak in your trap for it to dry up that fast. I know of a church addition that developed a leak in one of the waterlines under the men's bathroom. It was seeping up through a small crack in the concrete floor, and suddenly one Sunday the floor was completely dry. Upon close investigation I discovered a small hole had been drilled in the floor drain trap, allowing the seepage to go directly into the trap instead of coming up into the building first. A brilliant idea, I thought, but after we fixed the waterline leak, we had a perpetually dry floor drain trap because of that hole. I finally managed to get a sheet metal screw in the hole, but it was a bugger, and it still seemed to dry out quicker than the trap in the ladie's room. Thank God for those extendable magnets or I'd have filled the trap with dropped screws. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
