TractorLinks.com
Tool Talk Discussion Forum
Re: Radial or Bias tires for cargo trailer
60 acre hillside
12-26-2012 11:42:55
I doubt if bias will be cheaper but I would much prefer bias. Radial offers three qualities each not needed with a trailer. They ride smoother, You do not need this. They get better traction. Again you do not need this because if it is a tandem they need to slip sideways in a bend, In fact a radial can grip the pavement so well that it can loosen from the rim. They wear better. Wear is not a consideration for a trailer tire used infrequently, Also a bias has a stronger sidewall.
I would pay a premium for bias.
RodInNS
12-26-2012 13:29:10
 Re: Radial or Bias tires for cargo trailer in reply to 60 acre hillside, 12-26-2012 11:42:55
BIAS trailer tires are not worth a flanegin _______.
Wether you use it once a year or every day the radial will pay you over and over. Radial will also cost you about 30% more.
I"ve seen bias trailer tires peel apart in less than 500 miles use. Smaller ones simply blow out... Never again will I own one.
Rod
