TractorLinks.com
Tool Talk Discussion Forum
Re: help with devilbiss 432
rpllr
12-26-2012 06:25:58
I rebuilt a devilbiss 445 pump and found parts online, bought rod bearings, rings, gaskets and valve parts for little over 300. Mine had a little rust at the top of the bore from sitting and was causing a knock.
gapfast
12-29-2012 17:33:51
 Re: help with devilbiss 432 in reply to rpllr, 12-26-2012 06:25:58
I just tore it down completely. Mosty oily water sludge inside. Crank and rods look rusted quite a bit.
haven't got bearings off of crank yet. There not just sliding off. Gonna clean it up a bit and go from there. Where is the best place for parts?
XRogerX
12-30-2012 16:55:29
 Re: help with devilbiss 432 in reply to gapfast, 12-29-2012 17:33:51
You can knock the roller bearings off pretty easy with an air hammer but be careful not to wreck the sheet metal cups on either end of the crankshaft.
Independent Components Corp and Parts Service International supplied most of the stuff I used to rebuild with. I"d go with OEM valve springs though, and double check bearing clearances and ring gap.
gapfast
01-01-2013 14:00:52
 Re: help with devilbiss 432 in reply to XRogerX, 12-30-2012 16:55:29
Crankshaft is in pretty rough shape! Id post a pic but my phone doesn't like it
gapfast
01-07-2013 16:58:07
 Re: help with devilbiss 432 in reply to gapfast, 01-01-2013 14:00:52
flywheel is 19". Papers I found on it say need a 20". Is that common?
parts service international said they had no parts. As far as icc they only sell to suppliers.
Maybe this thing is not worth rebuilding. I'm still pushin fwd though!
This post was edited by gapfast at 06:37:12 01/08/13.
gapfast
02-26-2013 05:13:58
 Re: help with devilbiss 432 in reply to gapfast, 01-07-2013 16:58:07
Roger, u had mentioned lapping valves in another thread. I have my valves pretty clean and I"m unsure what two edges u speak of. Could you post a pic? Also seen springs put in several ways. Which way do you prefer?
Thanks
Phil
